rear fender clearance
- jim_palmore
24 Dec 2007 15:15
I have a 91 kz1000p and have taken off the rear fender to put a fatbob type fender on. the bike was lowered 3" using shorter shocks. when I took the stock fender off I found that the wheel had rubbed the tail light wires off. I plan to reroute the new wires to keep them out of the wheels path.
my question is , what is the appropriate spacing distance needed to prevent the tire from bottoming out on the fender. I don't want to damage the tire.
another concern is to ensure that the swing arm doesn't hit the end of the fender. I want to keep that end as low as possible to keep as much road grime as possible off of my battery and electronic componates..
ENJOY LIFE,, THIS IS NOT A DRESS REHEARSAL.
1991 KZ1000P FROM COPPER TO CHOPPER. MY BADASS BOBBER
- mariozappa
Re: rear fender clearance
24 Dec 2007 15:46
Well.... what size is your rear tire? Is it a stock fender for a 91 kz1p?
1977 KZ650C1
and the KZ650/KZ750 Conversion
- jim_palmore
25 Dec 2007 11:50
the rear tire is stock and the new fender is a blank fatbob .the blank is going to be easier to customize the mount points and not have ugly unused holes in it
- mariozappa
26 Dec 2007 05:29
Sorry. Now that I've reread the first sentence, I see you already told be that! :laugh:
I don't have an answer for you, but maybe someone will chime in here... :whistle:
1977 KZ650C1
- romzrx
29 Dec 2007 17:49
You shocks are to short,you should not touch the fender when bottom out your rear suspension.I would give 1/2" to 1" clearance.
76 KZ900
79 KZ1300
82 KZ1000J
C10
C14
ZRX1200
79 KZ1300
82 KZ1000J
C10
C14
ZRX1200
- jim_palmore
29 Dec 2007 23:30
I bought a sportster fatbob fender off ebay and plan to cut the rear rack that held the radio and mount the fender there. I'm going to use 1/2" steel pipe to make a sissy bar to mount my rear light and license plate to.
- jim_palmore
07 Feb 2008 21:49
found out that the travel on the swing arm is about 4"
- love2ride
- Ngati Tumatauenga
08 Feb 2008 05:07
How about getting rid of the shock and replace it with a strut. Rigid ride, but no issues with anything rubbing at all. Plus you can go as low as you want.
Newport News, Va
2006 Ninja 250 - Commuter
1978 KZ1000 - Not even close to stock.
- PLUMMEN
08 Feb 2008 09:02
how about stiffening up the preload on your shocks?
Post edited by: PLUMMEN, at: 2008/02/08 12:02
- jim_palmore
08 Feb 2008 11:45
gonna set the preload so I can change for 1up 2up. as far as struts ,,,did the whole hardtail thing when I was younger. too old now
