I HAVE FRONT BRAKES!
- primemover
23 Dec 2007 11:24Hi all...
just wanted to touch base and say a HUGE THANK YOU!
I reassembled my 1978 KZ400 front brakes and everything appears to be in order!
yes, bleeding was a pain (and i question my wisdom of painting the calipers BEFORE the reassemble - as they are now a mess again - but will do my best to do a "touch up" with them either on the bike, or hanging to the side), but i finally got a pretty good/steady stream of only fluid coming out the bleed valve (using a syringe and tube system) so i decided... ENOUGH!
i capped the mast. cyl., cleaned everything up as best as i could and (drum roll please...) tried the front brake lever....
at first, the piston only moved a little, but after a few tries, it make contact with the rotor...
i gave the wheel a spin and BOOM! The thing stopped on a dime!
the pads do rub the rotor a little (so the wheel does not spin completely freely - though this is probably normal)... i also suspect that once this bike hits the road (sometime WAY in the future), the pads will wear down appropriately and the wheel will spin a bit more freely...
anyway...
i'm thrilled!
i'll be moving onto other "front end" stuff soon...
thanks again for your combined help/advice...
best wishes for a happy holiday season!
- prime
- BSKZ650
Re: I HAVE FRONT BRAKES!
23 Dec 2007 13:29
wohoo, bleaing brakes on these bikes has always been a real pain in the butt, glad you got things working;)
77 ltd1000, current rider
76 kz900, just waiting
- HerrDeacon
23 Dec 2007 15:17
Good to hear! I'll be putting mine back on and bleeding them in the next month. From what I hear, I'm not looking forward to the bleed process
- mariozappa
23 Dec 2007 16:22
:laugh:
:laugh:
Welcome to the CLUB!
:laugh:
BTDT!
:laugh:
:laugh:
BTDT!
1977 KZ650C1
and the KZ650/KZ750 Conversion
