KZ440 rotors and calipers (and pads)
  • kamiwaza
  • kamiwaza's Avatar Topic Author
19 Dec 2007 21:05
#185790
I live in Taiwan (where there are no old KZs like mine) and I have what appears to be a Japanese-made 1980 KZ440 A1 LTD. It has a 19" mag wheel front, with a 7 bolt rotor on it. The caliper uses oddly-shaped pads, one of which uses a screw to affix it to the caliper.
I'd like to overhaul my caliper and get new brake pads, but when I look on e-bay, all the wheels and rotors have 4 bolts, and the brake pads seem to be different! I want to know:
  • Is my wheel different because it's Japanese and not US-made?
  • Is there any difference between the calipers of the 7 and 4-bolt bikes?
  • Where can I get rebuild kits and brake pads for my bike?
  • Thanks for any help anyone can give me with this.
    Post edited by: kamiwaza, at: 2007/12/20 01:26
    • Samwell
    • Samwell's Avatar
    Re: KZ440 rotors and calipers (and pads)
    20 Dec 2007 02:46
    #185806
  • Thanks for any help anyone can give me with this.<br><br>Post edited by: kamiwaza, at: 2007/12/20 01:26
    According to the parts diagrams, the KZ440 A1 LTD from 1980 should have a 4 bolt rotor. The most likelt explanation is someone swapped wheels a while ago. If memory serves, the shaft drive bikes of that era had seven bolt rotors. Someone probably changed wheels.
    Hope this helps...
    • kamiwaza
    21 Dec 2007 22:06
    #186017
    Thanks Samwell. It helps, but it's little comfort. If it sheds any more light, my front and rear mags are different OEM - the front is Enkei, the rear Asahi. Don't know if this is normal or not.
    By shaft drive, I guess you mean bigger KZs. There weren't any shaft-drive 440s, correct?
    • Samwell
    • Samwell's Avatar
    22 Dec 2007 02:13
    #186025
    AS far as I know, the shaft drives were only 1000's and 1100's.
    My KZ1000A2 has pads like you describe. The inboard(closer to the wheel) pad is held on with a screw. They are a bit odd shaped too, mostly circular with the top and bottom are flat.
    kawasaki.com will have a parts diagram and EBC brakes, will have pictures of pads so you can match things up.
    Sam
