Gear shift lever for big feet?
- Little B
16 Dec 2007 00:06
Anyone know where I could get or if they even make longer gear shift levers for the KZ750? I've seen them available for other bikes but never seen the option for KZs.
1981 KZ750-H2 LTD
- Bluemeanie
Re: Gear shift lever for big feet?
16 Dec 2007 19:24
Don't know if something like that is available BUT if you handy with a welder or know someone who is it's real easy to modify it to your liking. Only problem would be painting it or rechroming? :S
- The Milkman
16 Dec 2007 19:52
The last pair of boots I bought had a thick sole on them, I had to raise the shifter lever up one notch on the shaft to make it comfortable to use,,, would this help you?
Post edited by: The Milkman, at: 2007/12/16 22:53
- Little B
16 Dec 2007 19:58
I don't know, it might help some to move it up a notch. But I think the issue is that my foot has to be a ways backwards in order to use it properly. hmmm
1981 KZ750-H2 LTD
16 Dec 2007 20:34
Little B wrote:
Am uncertain about length difference or fitment to KZ750, but oem shift lever on Z1/KZ900 is 6 1/2 inches from center of spline hole to center of end tip. Guessing KZ1000 continued with same lever.
Many Z1/KZ900 riders prefer shorter levers to move the contact point behind (instead of over) the big toenail.
