1977 A Rear Caliper on 1977 B1 wheel
- kenskz1000
09 Dec 2007 06:14
Will a 77 rear spoke wheel caliper work on a 77 mag wheel both are 1000?
- 76 LTD
Re: 1977 A Rear Caliper on 1977 B1 wheel
12 Dec 2007 14:13
as far as i know it will (one sure way to find out though)try it and see.
- kenskz1000
12 Dec 2007 14:54
My B1 caliper piston is junk, there is a 77 a model caliper on e-bay right now and was not sure if I should bid or not. I'm not sure if there is clearance with my 16 inch mag.
- kenskz1000
12 Dec 2007 14:55
- kenskz1000
12 Dec 2007 14:55
12 Dec 2007 16:14
Perhaps try kawasaki.com to determine whether the part is common to both models.
- i800phyco
12 Dec 2007 16:25
I have the combo in question it works alright.
before the gs11 swingarm this was mounted on the stock 77a1 swingarm.
Only issue I had was the rotor was tight on one side of the caliper and that was probably because I tried to use the a1 rotor on the ltd wheel, I installed an ltd rotor and all was well.
Ham lake, MN.
77&78 KZ1000A's
A nice 79 1000LTD
And a pile 80 1000LTD
Plus a few others.
77&78 KZ1000A's
A nice 79 1000LTD
Plus a few others.
- bob_z1
12 Dec 2007 18:36
I thought the rotor on the B(LTD) was a different diameter than the one on the A(standard) model ?
Post edited by: bob_z1, at: 2007/12/12 21:39
- arai59
12 Dec 2007 19:37
Your right Bob. The LTD rear rotor is different. It also fits the 750 twin. You'll need the stock 77 caliper and mount also. That or swap out to 78 or later. The 77 LTD rear is unique to that model. I just went thru this recently.
Post edited by: arai60, at: 2007/12/12 22:42
Post edited by: arai60, at: 2007/12/12 23:00
- i800phyco
12 Dec 2007 19:52
I believe the rotor I have on there is a 80b4. I know the wheel is a 78b. I assumed 77-78 ltd where the same in the rear.
Ham lake, MN.
77&78 KZ1000A's
A nice 79 1000LTD
Plus a few others.
77&78 KZ1000A's
A nice 79 1000LTD
Plus a few others.
- arai59
- arai59
