Stock bars to new clubmans
  • Radbear
  • Radbear's Avatar Topic Author
17 Jan 2006 22:18
#18388
Hi guys,
Just bought some new clubmans for my KZ650B that I'm turning into a cafe .Can anyone tell me how to change them over? Currently my wires run through my stock bars...am I in for big trouble or should I bring the bike in to get it professionally done?:whistle:
  • rstnick
  • rstnick's Avatar
  • Premium Member
  • Premium Member
Re: Stock bars to new clubmans
18 Jan 2006 07:11
#18425
Welcome to KZR.
I'm putting Clubman Bars on my 650 as well this Winter. Now I've had non stock bars on for years, so I had modified my handlebar switches to allow the wires to run outside the bars. I just filed an openning to allow the wire to run out of. Some will drill the new bars and run the wires through. Some bars will come with holes already in them, but they may not line up for your purpose.
Post edited by: rstnick, at: 2006/01/18 10:12
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
  • solomrus
  • solomrus's Avatar
18 Jan 2006 11:37
#18475
you should be able to pull the wires thru the bars.
you will need to gain access to the main junction at the front of the harness. the wires from the bars should join up to the harness there with bullet connectors.
the wires should be color coded, do one side at a time. remove all the bullets from the junction for one side, work the wires out, then run them back to the junction and plug them back in.
lather, rinse, repeat for the other side.
i've not done this in probably 13 years, so if i forgot something, someone please chime in.
--r
198o kz1ooo Bravo Four
  • The Fish
  • The Fish's Avatar
19 Jan 2006 04:41
#18624
Some clubman bars arent hollow where the bars are welded together. Blow through the end to see if yours are. Some have sharp edges where they are welded together. Figure out where the wires will be and put extra electrical tape where the sharp edges will be.
If you put a string in the end (where the wires enter) and blow it through with air pressure it should come out of the center (where the wires exit). This makes it easier to pull your wires through the bars. Push the wires in while pulling on the string. It will take some time but the clean look is worth the effort.
Fish
  • Wildog
  • Wildog's Avatar
19 Jan 2006 08:51
#18656
I had the same problem when I did mine, when I got to looking at old-school cafe bike pictures almost all of them left the wires out, I just got some of that braided stainless wire loom off line and ran my wires through it. Gives it a custom look, and I spent way less time, you will have all od the wire disconnected anyway. Depends on the look you want I guess. Just remember if you have wiring trouble or need to replace a switch in the future maybe leaving the wires out will benefit you. Here is a link.
cgi.ebay.com/ebaymotors/BRAIDED-CABLE-HO...QQrdZ1QQcmdZViewItem
Post edited by: Wildog, at: 2006/01/19 11:53
  • Kidkawie
  • Kidkawie's Avatar
  • I bleed premix
19 Jan 2006 09:07
#18661
You will have brown braided wires unless you spring for the stainless.
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
  • wireman
  • wireman's Avatar
19 Jan 2006 19:07
#18781
how about eliminating the handlebar mounted electrical stuff and mounting it somewhere else?i dont have turnsignals or horn or flashers or any of that kind of stuff on my bikes so it really simplifies things for me!goodluck,happy wrenching! :whistle:
Post edited by: wireman, at: 2006/01/19 22:08
  • dutchz
  • dutchz's Avatar
19 Jan 2006 23:25
#18833
Just did this today on my wifes 650. Solomrus is right on the money.
1974 Kawasaki Z1
Stock front hub and rear axle.
  • dutchz
  • dutchz's Avatar
19 Jan 2006 23:26
#18834
1974 Kawasaki Z1
  • guitargeek
  • guitargeek's Avatar
  • Elitist, arrogant, intolerant, self absorbed.
20 Jan 2006 12:11
#18932
I've found that stuff to come in really handy at times! You do take your bikes on public roads... right?
1987 KZ1000-P6 "Ponch"
1979 GS1000 "Dadzuki"
  • wireman
  • wireman's Avatar
20 Jan 2006 18:36
#18991
arm straight out for left,out and up for right turn piece of cake!right out of the drivers license manual,dont have mirrors or turn signal brackets on frame or reflectors found i tend to concentrate more on whats going on around me more rather than hoping that other people see a turn signal flashing.goodluck,happy wrenching!:whistle:
