\"Hooks\" on rear of frame?
- Aric
01 Dec 2007 19:52
Recently picked up an 82 550 LTD. Was out looking at the frame near rear fender and noticed 2 L-shaped "hooks" on either side of frame near the stock turn signal mounting holes. The "hooks" are L shaped about 3/16 diameter with a 1/4 inch ball at the end. Anybody know what I'm referring to and what it's purpose is? The bike is almost completely disassembled so it may become obvious on reassembly but I was just curious. Thanks in advance. Sorry no pics right now.
- The Gringo
- ¡Usted no necesita otra motocicleta!
Re: \"Hooks\" on rear of frame?
01 Dec 2007 20:48
No big mystery, those hooks are there to attach bungie cords to.
Andy
Akron, Ohio
80 Z-1 Classic-Sold
84 GPZ1100
79 KZ 1000 LTD
78 KZ 1000 A2
77 KZ 1000 LTD-Sold
KZ 550 times 2 80 440LTD-Sold
Akron, Ohio
80 Z-1 Classic-Sold
84 GPZ1100
79 KZ 1000 LTD
78 KZ 1000 A2
77 KZ 1000 LTD-Sold
- RetroRiceRocketRider
Re:
02 Dec 2007 08:12
The Gringo wrote:
Nuh uh, those are "grab hooks" for passengers with tiny fingers. :whistle: :laugh:
The Gringo is right, those are hooks to be used when anchoring something (passenger helmet, small package, etc) to the back seat with bungee cords.
IIRC though, they should be pointing straight down, not bent into an "L" shape?:huh:
It's likely that the PO of your bike figured that the little "balls" on the ends weren't enough to keep the bungee cord hooks from slipping off, so he/she bent them. :S
Covina, So Calif!
78 KZ650-B2 = SOLD
84 ZN700 LTD = SOLD
84 ZX750 GPz = SOLD
89 GSX1100F Katana = SLEEPING
78 KZ650-B2 = SOLD
84 ZN700 LTD = SOLD
84 ZX750 GPz = SOLD
- The Gringo
Re:
02 Dec 2007 08:47
Actually there are 4 of these, the 2 at the rear are bent in an L shape they start out running horizontal towards the rear and then bend vertical. There are also two that are in front of the shock mounts that point straight down. I would guess the best way to use them would be to criss cross them ie: rt. rear to lf. and lr. to rf. Funny I never paid much attention to them.
Post edited by: The Gringo, at: 2007/12/02 11:50
Andy
Akron, Ohio
80 Z-1 Classic-Sold
84 GPZ1100
79 KZ 1000 LTD
78 KZ 1000 A2
77 KZ 1000 LTD-Sold
Akron, Ohio
80 Z-1 Classic-Sold
84 GPZ1100
79 KZ 1000 LTD
78 KZ 1000 A2
77 KZ 1000 LTD-Sold
- Aric
Re:
02 Dec 2007 19:30
Thanks Guys!, kinda figured that's what it was, now I remember using them for just that purpose on my 650 years ago.But I've been known to use many things for purposes they were not designed for. The P.O. has also twisted the fuses, selonoids, wires, switches, etc into a huge snaking mess, as well as installing non KZ turn signals. Anybody seen any decent pics on the forumof a correctly mounted and wired fuse/wiring block or know where I can find an easy to read wiring diagram (manual is a bit confusing). At very least can someone confirm my assumption that KZ's do run on a 2-wire turn signal system?
- hardr0ck68
- Who put the what in the where?
Re:
02 Dec 2007 19:51
My 650 runs a 2 wire system up front (with an internal ground) one for the running lights and one for the turn signal.
In rear it is 2 wires, just turn signal and ground.
1977 kz650 c1
bought it because I was told it would never run again...I like to prove people wrong.
- RollingStock
Re:
02 Dec 2007 20:10
i have a 82 550a it uses 2 wire also..
i can take a pic after work ..
73 z1900 street nitrous drag bike(powered but honda)
83 kz750 turbo street fighter project
