best way to clean up/clean out an old mast. cyl.
  • primemover
  • primemover's Avatar Topic Author
01 Dec 2007 11:33
#183368
Hi all....
I have a mast. cyl. from an ~1980 KZ440 and am going to use it on my 1978 KZ400 (figured out that this SHOULD be ok)...
anyway, the mast. cyl. is in good shape, but looks awlful...
i've taken it all apart, emptied it out, taken off all the brakelines (working on the calipers some other day)...
the outside needs some TLC (i figure, sand it down, perhaps prime it, then paint it)...
the inside has some "goop" at the bottom (brown/tanish)...
is there some kind of solvent i should use (or just elbow grease)?
thanks...
- prime
  • OKC_Kent
  • OKC_Kent's Avatar
Re: best way to clean up/clean out an old mast. cyl.
01 Dec 2007 14:17
#183387
You can use brake fluid to clean it, I have used alcohol too. Buy some small brushes. A gun cleaning brush kit would come in handy.
Cashion, OK
78 KZ650 B2 85,000+ miles
  • primemover
01 Dec 2007 14:32
#183389
hi...
i've heard that brake fluide does a number on paint (i guess in this case, i can USE that to my benefit!)..
thanks..
  • RonKZ650
  • RonKZ650's Avatar
01 Dec 2007 15:00
#183394
You can clean it with dot5 fluid if you don't want the paint further ruined, or denatured alcohol.
  • BSKZ650
  • BSKZ650's Avatar
03 Dec 2007 04:25
#183628
since you are rebuilding it, use some carb cleaner, that should remove all the nasty stuff, then clean it well with brake fulid to remove any residue left.
I would also put dot 5 in the new rebuilt system, a whole lot better product
77 ltd1000, current rider
76 kz900, just waiting
