KZ900/KZ1000 Rear Sprockets
- 79MKII
- Love Them Kaws!
27 Nov 2007 09:21
Can anyone tell me if the rear sprocket bolt patterns are the same for the KZ1000 and the KZ900 w/drum brake? I think the 900 LTD w/disc brake is the same, but I'm not sure about the drum. I'm looking to use a KZ900 spacer on my 1000 if it will work, item 31 92026-108 SPACER,REAR HUB shown below. Thanks
The Kaw List:
- bob_z1
Re: KZ900/KZ1000 Rear Sprockets
27 Nov 2007 19:02
KZ900LTD takes a different sprocket than any other 900/1000.... and if my fading memory is right the drum brake bikes are different than the disc bikes.
- 79MKII
- Love Them Kaws!
27 Nov 2007 19:17
I think you're right. I was looking on the web site for JT sprockets and none of the 900's share the same rear sprocket with any of the 1000's.
I was hoping to use one or two of those to offset my rear sprocket. Back to the drawing board...
The Kaw List:
- arai59
- Visitor
27 Nov 2007 20:39
Mike, they are completely different. Sprocket carrier size and bolt pattern. On the drum brake that is.
- 79MKII
- Love Them Kaws!
27 Nov 2007 21:29
Thanks for the confirmation. I thought I was on to something there. Any other ideas for a rear sprocket shim?
The Kaw List:
- arai59
- Visitor
- 79MKII
- Love Them Kaws!
28 Nov 2007 13:26
I've got a big conversion going on and the chain is hitting the 180 rear tire. :ohmy:
The Kaw List:
- arai59
- Visitor
28 Nov 2007 17:03
Are you using offset sprockets with a smaller chain ? I think you can find this conversion pretty easy. Many here and elsewhere have done it. Besides the shim on the 900 is pretty thin and probably not be enough space to clear a 180.
- 79MKII
- Love Them Kaws!
28 Nov 2007 17:41
Yes, I have a 14mm offset front and a 15mm spacer on the rear, and the tire still hits. I think it's because I went with a 6" rim and not a 5.5". I also went down to a 530 chain, but that doesn't really help because they are the same width as a 630. I'm looking heavily into a 520 conversion now, but I think I'll still have to shim. The problem I'll soon run into is the chain/frame clearance. It's barely clearing now even with the chain hitting the tire. I think a narrower chain AND the rear sprocket shimmed should do the trick. I'll try to attach some pics...
The Kaw List:
- 79MKII
- Love Them Kaws!
28 Nov 2007 17:42
The Kaw List:
- 79MKII
- Love Them Kaws!
28 Nov 2007 17:43
And finally the finished product (or so I thought!)
Sure wish I knew how to post more than 1 picture...:whistle:
The Kaw List:
- arai59
- Visitor
28 Nov 2007 19:38
Beautiful work Mike ! Maybe you can visit a local machinist and have him build you the spacer you need. Have you checked with APE ? Or any other go fast guys ?
