Gas Tank Strap
- 79MKII
- Love Them Kaws!
Gas Tank Strap
21 Nov 2007 09:30
OK, it's been a while since I disassembled this bike, and my memory is apparently not what it used to be. I seem to have forgotten how to install the rubber tank strap at the back of the tank. :blush:
Does it go up and around the frame or up through the oval in the middle or what? Did it go where the gussets are now maybe? Nothing seems right...
Could someone post a picture??
Thanks
Post edited by: 79MKII, at: 2007/11/21 12:37
Thanks
The Kaw List:
- StreetfighterKz
Re: Gas Tank Strap
21 Nov 2007 10:15
If memory serves me correctly it goes around the frame tubes then to the tank. I have no idea what the oval hole is for in the gusset.
Later, Doug
Later, Doug
1978 z1000 Streetfighter
1976 z900 ‘Stripfighter
1978 z1000 w/RC Turbo
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
1979 z650 Resto-Mod
2018 Z900RS
- Mcdroid
- Gone Kwackers
Re: Gas Tank Strap
21 Nov 2007 12:20
Reach around the backside of each of the outside tubes and you should find a knob sticking out of the tube. The strap has a hole on each end. The strap sits on top of the frame tubes with each end stretching around the tube and fastening onto the knob. The hole in the gusset has nothing to do with the strap.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- 79MKII
- Love Them Kaws!
Re: Gas Tank Strap
21 Nov 2007 13:15
Mcdroid wrote:
"Reach around and find a knob sticking out"??:ohmy:I don't know what goes on in Texas, but no thanks!
Actually, that's how I had it and it does seem the best. Just thought there would be a better way. Just wanted to make sure. Thanks!
Post edited by: 79MKII, at: 2007/11/21 16:50
The Kaw List:
- racer54
Re: Gas Tank Strap
21 Nov 2007 15:06
That hole was put there to make the bike lighter!
- bob_z1
Re: Gas Tank Strap
21 Nov 2007 23:46
don't know if it's why the hole in the gusset was put there, but when new the Z1's had the carb vent tubes routed thru that hole
