750 forks on a 650
  • lucas808
  • lucas808's Avatar Topic Author
750 forks on a 650
13 Nov 2007 12:30
#180869
Quick ????
can i put a set of 750 forks on my 650, not sure if they would bolt in or not, they look biger that the 650.
  • mariozappa
  • mariozappa's Avatar
Re: 750 forks on a 650
13 Nov 2007 12:50
#180872
The fork should both be 36mm. The 750 LTD had a triple tree that was a little wider.
They should slide right in. They did on my 83 750 ltd and 77 650.
1977 KZ650C1
and the KZ650/KZ750 Conversion ;)
  • lucas808
13 Nov 2007 12:53
#180875
thanks, i am doin a zx6 swap and was goin to use the 750 fork to use the parts off of, so if i wanted to change it back later i didn't have to mess up the stock 650 ones.
