KZ1000 Swingarm
- Oldwolf
KZ1000 Swingarm
12 Nov 2007 17:48
1)Is there any benefit from going from a 1977 KZ1000A1 swingarm with one set of needle bearings to a 1978KZ/LTD1000 swingarm with 2 sets of needle bearings. 2) Also is there any difference in the KZ vs. LTD swingarm other than placement for the chain guard tabs. 3) How much improvment is realized in converting to a GS1100 aluminum swingarm set up. I have read in these posts that the GS1100 arm is about 1.5 to 1.75 inches longer than the stock KZ arm do you have to extend the rear fender out by this distance to avoid the tire rubbing the fender. I notice that Red Line Cycle extends their fenders when they install a 2 inch over arm. Thanks for any thoughts, answers or opinons on these Questions. Ed
1977 KZ1000A1, 1105cc,Mikuni RS34mm FS, K&N Pods,Kerker 4/1,Dyna S Ign,Coils & Plug Wires,Progressive Sup. Front&Rear, Derale Oil Cooler.
- donthekawguy
Re: KZ1000 Swingarm
13 Nov 2007 12:13
The GS arm is a lot stronger than the KZ arm being that it is boxed and aluminum. I never did get around to putting mine on so I'm not sure about the rear fender. Most people are taking off the rear fender anyways.
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
1971 Kawasaki g3ss
1972 Yamaha R5 350
1964 Yamaha 125
- Samwell
Re: KZ1000 Swingarm
12 Apr 2008 17:37
Oldwolf wrote:
Initially, I'd say that 4 bearings are better than two. But, If you look around at newer designs (my '02 Warrior for example) its heavier, made more power and torque, yet it used one bearing on each side and had the centre bushing, just as the '77 kz1000 does.
The end result is, if your parts are in spec, I'd say you'd be hard pressed to tell the diff....
Sam
Sam
- racer54
Re: KZ1000 Swingarm
12 Apr 2008 20:58
You should be able to move the tire back 2" without it rubbing. I have seen it done before. Looks a bit different because the tire is closer to the fender though. Lots of guys take the fender off but others make a plate and drill holes to move the fender mount 2" farther back. Moves the taillight that distance back. This keeps the stock look and unless you are up on these bikes,you can't tell it's been done. Where the mount that goes over the frame under the tail piece bolts to the fender(rubber-mounted), use the plate to bolt to the mount and bolt the fender 2" back in the new holes you drill.
