SR rotors?
- Bluemeanie
SR rotors?
09 Nov 2007 15:54
My new ebay (very nice) forks have the caliper mounting bolts about 5/8" lower than my old forks. I was informed on another site that I may have SR forks. Apparently they use smaller rotors (mine is 11 11/16 or 297mm diameter). Does any one here have a SR rotor off a bike to give me a measurement? I need diameter and back spacing (see pic) My rotor says min thickness 4.5mm on back. Using an SR rotor may solve my problem! Thanks...
Post edited by: Bluemeanie, at: 2007/11/09 18:56
- SLEEPER650
Re: SR rotors?
09 Nov 2007 16:22
The rotors on my sr are 10 7/8 1.25 back spacing
78 650sr my baby
78 650sr waiting for rebuild
82 kz1100
82 kz1100
- SLEEPER650
Re: SR rotors?
09 Nov 2007 16:24
i have a spare set of rotors but they are not drilled
78 650sr my baby
82 kz1100
82 kz1100
- Bluemeanie
Re: SR rotors?
09 Nov 2007 16:43
The 10 7/8" sounds good, the 1.25 bothered me. I checked mine again but this time put the tape in the center hole measuring to the top (duh!) My 53 yo eyes came up with just under 1 3/16". Problem is that I really need to "borrow" a SR rotor and mock it up to see if it works. Can you somehow measure from center of axle to lower caliper bolt? I think a straight line would work. Thanks... John (below is my fork problem, new fork on bottom)
Post edited by: Bluemeanie, at: 2007/11/09 19:47
- SLEEPER650
Re: SR rotors?
10 Nov 2007 07:55
From the bottom of the fork where the stud screws in to the center of the lower bolt hole is roughly 2 1/2 inch.
78 650sr my baby
82 kz1100
82 kz1100
- Bluemeanie
Re: SR rotors?
10 Nov 2007 15:32
Thanks sleeper, you stepped up and gave me crucial measurements. Mine are the same as yours so it appears I have SR forks designed for dual discs. Mine is a single disc, a little worried going to a smaller single. I don't have the moola to convert to dual. It should work fine as my single disc stops so good it's almost too much! Another member here just straightend his forks with great results, I have access to a press so will try that too. I would really like the original front end back on, don't want a frankenbike if I can help it. Thanks again sleeper, you've been a great help. Ride safe...
