What to do with the turn signal lights when changing handlebars?
- Little B
06 Nov 2007 05:51
For those of you who've changed your bikes bars and the turn signal lights were originally on the ape bars, what did you do with them once the new bars were on?
I'm leaning towards changing mine to Daytona bars, possibly the Euro ones & I don't think there is enough room to mount the signals back on.
1981 KZ750-H2 LTD
- wiredgeorge
Re: What to do with the turn signal lights when changing handlebars?
06 Nov 2007 05:57
Your headlight shell is likely held by two arms mounted on the fork tubes. The shell will then be retained to the arms by a large bolt/nut on each side. Get turn signals that have threaded posts and put the posts through the holes instead of the bolts and put a nut on the backside. The wires for the signals will then be inside the headlight shell for connection to the wiring harness.
- JMKZHI
Last edit: 03 Dec 2008 20:26 by JMKZHI.
- Little B
06 Nov 2007 10:13
That is great help guys, Thanks!
1981 KZ750-H2 LTD
- iandz500
07 Nov 2007 15:23
i relocated mine lower down through the headlight brackets when i fitted ace bars, i fitted much smaller aftermarket ones though! can send you a photo if you wanted to see what it looks like
Iand
Iand
Bikes: 1960 lambretta Li125 sold; 2001 Honda CG125 sold; 2006 Yamaha FZ6 sold; 1980 Kawasaki Z500 sold; 1967 BSA Bantam D10; 2008 Aprilia Shiver sold; 2010 KTM Duke 690R; 1954 BSA Bantam; 1980ish Kawasaki Z200
- xstreamcanadian
12 Nov 2007 20:43
My SR had the same turn signals, hung from the bars, I picked up some cool old chromed harley(yes I know I know) signals, and then bought chrome mounts made for them from a custom chrome shop online(harley also sells them)this was you can mount to the upper stanchions. They look very nice and are similar in size to the originals so it doesnt lose the look of the era.
my two cents...
Post edited by: xstreamcanadian, at: 2007/11/12 23:44
my two cents...
- Little B
18 Nov 2007 00:27
Good ideas...I'd be up for a pic of how yours came out too iandz500. If you can post it in this thread, that would be ideal.
1981 KZ750-H2 LTD
- 2M4Dale
18 Nov 2007 04:12
Hello from Sunny Mansfield, Ohio
1980 KZ750H1 LTD
1981 KZ750H2 LTD
1980 KZ750H1 LTD
1981 KZ750H2 LTD
- Little B
18 Nov 2007 21:49
Those look really good. Those of you who can just 'fabricate' stuff amaze me. I'll need to experiment and see what will work best/look decent.
1981 KZ750-H2 LTD
- Little B
06 Feb 2008 21:19
JMKZHI wrote:
JMK - What kind of dampers are you talking about? I'm at the point that I'm going to do this and don't want to not order something that I need.
Yep, ditto. That's how I did it on my 81 650-CSR.
Here's the type of stem I installed: 75mm stem - click!
I also got some dampers to fit the oblong flange. JMK.
1981 KZ750-H2 LTD
- JMKZHI
Last edit: 03 Dec 2008 20:30 by JMKZHI.
- Little B
07 Feb 2008 14:39
Thanks!
1981 KZ750-H2 LTD
