how to shorten stock forks?
- badboie
02 Nov 2007 06:56
I like my stock forks. They work great for me, I might have to replace the seals but anyways what i was wondering was, what is the best way to shorten the forks I would like to bring my front end down a bit. anyone got any ideas?
- Bluemeanie
Re: how to shorten stock forks?
02 Nov 2007 07:18
It would take a good machinest and some $$$. However, you could (space permitting) slide your forks higher up in the triple tree.
- galaxian
02 Nov 2007 09:18
2 ways.
The poormans way slide them up through the triples. Depending on your type of bars (they will hit) the possibilites are endless.
THe $35 dollar way, send your forks to Franks engineering they will machine then to any length for $35. www.frankmain.qpg.com/ . Need to adjust the springs as well but that can be done yourself.
I have done both. Each has its pros and cons.
1977 KZ1000A1, 1979 KZ650 C3
- 79MKII
- Love Them Kaws!
02 Nov 2007 09:42
If you are taking them apart to replace the seals, you should do it the right way and install lowering blocks. They mount easily inside the forks and come in various sizes from about 1" to 4". This way, you could always return them to stock length, if desired. By the way, I just may know someone that has an extra set...:whistle:
The Kaw List:
- badboie
02 Nov 2007 14:58
ooooo! who has this extra set and for how much would they want for them??:woohoo:
- 79MKII
- Love Them Kaws!
02 Nov 2007 15:06
I'll see what I can find out and send you a PM.
The Kaw List:
