Triple tree problem
- Bluemeanie
Triple tree problem
01 Nov 2007 14:35
Started taking my bike apart today (bent fork), had to tap the left fork out of the tree. Upon inserting new fork I found it to be about 1/8" off center on the upper clamp. I can pull on fork slightly and push with my finger and it centers. So apparently my lower left clamp on tree is bent slightly. I can see it. I have no money now and was wondering if anybody here has ever tweaked them a little bit? I was thinking of inserting old fork in and using as a long lever. Is this a workable thing or am I screwed and have to rip it apart futher? Thanks guys
Re: Triple tree problem
01 Nov 2007 15:57
You might want to see if this is the same as yours:
This one might fit
Post edited by: KZCSI, at: 2007/11/01 21:41
This one might fit
- rdgrnr
01 Nov 2007 17:33
I bought something from that guy 3 weeks ago. Still waiting to get it. I think that guy gets "jacked-up" quite a bit:silly:
77 KZ650B1
80 440 LTD Sold
78 GL1000 Naked Wing Sold
80 CM400E Sold
Brainerd, MN
80 440 LTD Sold
80 CM400E Sold
Brainerd, MN
- KZQ
- Administrator
01 Nov 2007 18:48
Hi John,
From what you're describing something is bent. I'm not talking about the frame, I'm referring to the triple clamp itself. Can you fix it? Sure. Is it worth it, probably not.
Sorry Guy
KZCSI
Post edited by: KZCSI, at: 2007/11/01 21:50
Sorry Guy
KZCSI
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
Riders:
Projects:
1985 ZN1300
- flht1997
01 Nov 2007 19:17
do you have the right fork loose and the upper triple loose on the stem? or are you replacing left fork also?
Matt Milwaukee, WI
75' KZ400, (5) 78' KZ400, 76' KZ 750, 78' KZ650
78'CB750F, 78' CB550K
89' BMW R100RT
05' H-D Electra Glide
06' KLR650
Do it right or don't bother doing it at all.
89' BMW R100RT
06' KLR650
- Bluemeanie
02 Nov 2007 07:06
I don't have stem loose as you don't need to for changing forks. I am replacing right fork also. I'm going to pull that fork today. If right side is ok it will appear that left lower clamp is just slightly tweaked. If it was a major bend I would not even think about it, but so far it appears very minor. Like I said, going into top tube is only 1/8" off.
- flht1997
02 Nov 2007 07:42
sounds like it is just twisted a tad, i'd bet the right fork comes out hard and is an 1/8 inch off the opposite way. the lower triple is a pretty stout item, i would think the upper tripple would bend first.
i did not mean loosen the stem in the neck, i meant the upper triple onto the stem.
the last 400 i put together a few weeks ago gave me all sorts of headaches getting the forks to go back together, i suspect the front to a hit at one time, but, when together is goes straight, no wobbles, pulls or nothing
Matt Milwaukee, WI
89' BMW R100RT
06' KLR650
89' BMW R100RT
06' KLR650
- JMKZHI
Last edit: 03 Dec 2008 07:11 by JMKZHI.
- Bluemeanie
02 Nov 2007 09:19
Took only 10 minutes but right fork slid right out nicely and "new" fork slid right up in there as nice as can be! So I'm assuming the integraty of the tree has not been compromised? Lower left clamp does not appear to have been moved back, just twisted a tiny bit as bend in fork was close to it. The saga continues! By the way, a friend of mine provided these really nice forks for free! It's cool to have good friends!
- Bluemeanie
02 Nov 2007 10:33
Damn! Fork is about 3/4 inch longer which is workable, but upon closer inspection I found that caliper mounting holes are about 5/8 lower! I'm assuming these "nice" forks are now worthless junk to me? Any thoughts?
Post edited by: Bluemeanie, at: 2007/11/02 13:36
