center stand
  • leitrum
  • leitrum's Avatar Topic Author
center stand
14 Jan 2006 15:21
#17901
what ta bummer,i picked up a center stand for my kz440b std. its used and in great shape, but the stop is on the left of stand. on the kz440b std the exhaust, which is wherre the center stand stop rests against is on the right. want the stand on the bike so i can ajust brakes, change oil, etc. how can i get this center stand to work, guess stand was off a ltd with dual exhaust. help
  • RomSpaceKnight
  • RomSpaceKnight's Avatar
Re: center stand
17 Jan 2006 13:01
#18284
For racing I took my centerstand off but kept it in tool box. Used a 3/8 ratchet extension to hold it in place while bike in air. Won't help on side of road but it's in your tool box if needed.
  • TonyKZ1
  • TonyKZ1's Avatar
Re: center stand
17 Jan 2006 14:28
#18295
Well, you can make a stop for the centerstand to hit when it comes up and then bolt the stop to the left passenger footpeg. Sorta like what the 2-1 aftermarket exhausts come with. Its basically just an "L" bracket and the centerstand rests against it.
Tony
1997 Yamaha Seca II - mostly stock, Oxford Heaterz heated grips, a Scottoiler system. My Mileage Tracker Page
  • JR
  • JR's Avatar
Re: center stand
17 Jan 2006 19:31
#18351
Like Tony KZ1 says.
I got a simple L shaped bracket bolted to the passenger footrest and it works just fine as a centre stand stop.
