82-83 KZ1000R rear shock mount dimensions
  • loudhvx
  • loudhvx's Avatar Topic Author
25 Oct 2007 13:15
#178100
Does anyone know what diameter the upper and lower shock mounts are? The upper is a smooth shaft welded to the frame, correct? and the lower is a bolt? I need the diameter of the shaft and diameter of the bolt (10mm I think).
Post edited by: loudhvx, at: 2007/10/25 16:16
