Gas Cap Leaking
  • brox
  • brox's Avatar Topic Author
Gas Cap Leaking
24 Oct 2007 11:04
#177906
My gas cap has been leaking on my 1981 750 LTD. I replaced the rubber gasket, and still can smell gas from the gas cap. It is stinking up my garage, any other ideas to fix this? Thanks.
From Bismarck, ND
1981 KZ750 LTD w/Kerker Header
2006 KTM 200 XCW
  • RonKZ650
  • RonKZ650's Avatar
Re: Gas Cap Leaking
24 Oct 2007 11:07
#177908
Remember your cap is vented so air can get in the tank to replace gas as it's consumed, so it's normal to smell gas at the cap. If it's not leaking when you ride with a full tank, it's normal.
  • wiredgeorge
  • wiredgeorge's Avatar
Re: Gas Cap Leaking
25 Oct 2007 07:30
#178059
Is this the rectangular shaped cap? If so, even though you replaced the large seal ring, it may still not seal well. You need to replace the orings that go around the two M5 mount screws. These provide spacing to keep the cap tight on the seal. If you take the cap apart, you will find yet another oring around the key mechanism and this can leak as well... you will actually get gas come out the keyhole if this oring is shot.
  • brox
Re: Gas Cap Leaking
26 Oct 2007 12:26
#178264
Thanks. I will try replacing those orings next.
From Bismarck, ND
2006 KTM 200 XCW
