front tire size
  • 80G
  • 80G's Avatar Topic Author
front tire size
13 Jan 2006 18:40
#17780
On my 80 kz1000g, the current front tire size is 100/90/19. Would a 110/80/19 fit allright? I have transplanted a zx12 rear wheel that I plan to put on a 190 or 200 tire. The only matching set for the odd combination front and rear is a bridgestone Bt-020 if the 110 will work. Thanks
  • wireman
  • wireman's Avatar
Re: front tire size
13 Jan 2006 19:52
#17794
that shouldnt be a problem,what are you running for a motor in that stretched out monster?looks pretty mean!B)
  • steell
  • steell's Avatar
Re: front tire size
13 Jan 2006 20:13
#17799
You can go to the Bridgestone site and get the actual measurements for the tire, then measure between your forks to see if it will fit.
I just looked and it lists the tread width at 4.3" but it don't list the section width (the widest part). 26" tall and requires a minimum of a 2.15 wide rim.
www.motorcycle-karttires.com/
They list the BT45 100/90/19 at 26.1" tall and 3.9" wide.
  • 80G
Re: front tire size
15 Jan 2006 07:28
#17978
I am going with the stock 1000 for now. The only mod is switching from injection to carbs.
  • wireman
  • wireman's Avatar
Re: front tire size
15 Jan 2006 07:54
#17985
thats a lot of rubber you might need to get a cdl to ride with that loooooooonnng swingarm!bwaha what other tricks are you using on it?goodluck,happy wrenching!
