Anyone Know???
- BoZ650
- 77 KZ650 with 4 to1 and pods,Dyna Coil and Dyna S
Anyone Know???
18 Oct 2007 05:57
I just ordered a set of 12 1/2 inch shocks off a vulcan 750.They have a cap on top of each shock.I havent recieved them yet but was wondering if they might be air shocks?Didnt want to ask the seller for fear of him jacking up the reserve price!
77 KZ650 With 4 into 1 header,Air pods,Dyna Green coils,Dyna S Ignition and WiredGeorge coil mod!
- The Gringo
- ¡Usted no necesita otra motocicleta!
Re: Anyone Know???
18 Oct 2007 06:01
Yep that's what it is.
Andy
Akron, Ohio
80 Z-1 Classic-Sold
84 GPZ1100
79 KZ 1000 LTD
78 KZ 1000 A2
77 KZ 1000 LTD-Sold
KZ 550 times 2 80 440LTD-Sold
Akron, Ohio
80 Z-1 Classic-Sold
84 GPZ1100
79 KZ 1000 LTD
78 KZ 1000 A2
77 KZ 1000 LTD-Sold
- Bluemeanie
Re: Anyone Know???
18 Oct 2007 08:11
Yup, just pump away and it gets longer!!:woohoo: :woohoo:
- BoZ650
Re: Anyone Know???
18 Oct 2007 08:42
thanks guys.Gringo your the one who told me what shocks could be used!!Air shocks,are they any good.do they just change ride hight cuase i want them low to begin with.do i just take all air out?
- kz650csr81
Re: Anyone Know???
18 Oct 2007 09:59
I would not recommend taking all the air out... this would force the shocks to function outside there factory spec... now emptying most of the air to get a good starting point for adjustment... good.... just remember the less air and the lower the bike is the harsher the ride... too much air will have the same negative effect.. you should also try and find the info about recommended psi from factory... if you go to far outside the boundaries you will cause premature wear and tear of the shocks with the end result of wasted money..
safe riding
safe riding
Re: Anyone Know???
18 Oct 2007 10:48
Be careful to assure that letting all air out of rear air-shocks does not drop the rear suspension so much that the bike resting on side-stand tips over onto its right side.
So be ready to catch the bike if necessary to keep it from falling over onto its right side.
Post edited by: Patton, at: 2007/10/18 13:50
- BoZ650
Re: Anyone Know???
19 Oct 2007 03:33
Patton,I only need about an inch drop so I can touch the ground.But watch the right side huh?My bike leans to much left right now so maybe ill like the way it sit lowered.We will see,but ill definetly keep a watch for it!Thanks
Tony
Tony
- Makarth
Re: Anyone Know???
19 Oct 2007 20:33
BoZ650 wrote:
:blink: explain cause i might have same issue... :pinch:
Tony
- BoZ650
Re: Anyone Know???
20 Oct 2007 03:54
Makarth,My 650 leans a bit to much to the left for my liking.like the kickstand may be too short,but my spare is the same size!I was almost tempted to weld a piece to the bottom of the kickstand to get it to sit right.Some one here told me to bend the frame where the stand mounts to it but I just finished painting it and cant bring myself to do that!For now I put a 2by4 under it and it sits perfect.Only problem is its tuff to ride aroubd with a 2by4!
- BoZ650
Re: Anyone Know???
20 Oct 2007 03:55
- Bluemeanie
Re: Anyone Know???
20 Oct 2007 07:49
Boz650, It's not bending the frame, it's bending the outer mounting tab closer to the inner tab. Over time the outer tab bends out with wieght of the bike. Just a quick "tap" with a hammer will tighten thinks up. Put bike on center stand and see how much slop you have, this will confirm problem.
- Makarth
Re: Anyone Know???
20 Oct 2007 22:00
oh i thought you meant while riding :lol: well looks like im still left to my own devices :S
edit: i just reread entire thread... i think im almost qualified for retardation.
Post edited by: Makarth, at: 2007/10/21 01:03
