rear disc conversion for 81 kz650-h1
- kz650csr81
05 Oct 2007 11:14
Ok I have tried looking for this info through the archives and found tons of great information on different ways to convert the rear drum to disc... my question is which way is easiest??? most available??? most cost effective??? I have access to fab equip and people who know what they are doing but I would like to find something as close to bolt on as possible and still be able to keep a rear spoke wheel. any info would be greatly appreciated.. thanks in advance....
Jonathan
Post edited by: kz650csr81, at: 2007/10/05 14:17
Jonathan
- JMKZHI
Last edit: 03 Dec 2008 07:49 by JMKZHI.
- kz650csr81
Re: rear disc conversion for 81 kz650-h1
05 Oct 2007 13:57
I am figuring that the rear spoke will be the hardest to achieve... but like I said I can fab it up if I have to I just wouldn't know where to start and I would just rather not... I was hoping maybe there is some kind of conversion to the 750 mag with disc brake then from that starting point maybe another conversion from mag to spoke.... I dunno it sounds good on paper though
Post edited by: kz650csr81, at: 2007/10/05 17:01
- JMKZHI
Last edit: 03 Dec 2008 07:50 by JMKZHI.
- kz650csr81
07 Oct 2007 21:19
Well mags it is then.. will the wheels off a kz1000 LTD work?. I know you can polish them but do you know if you can have the mag wheels chromed?
Post edited by: kz650csr81, at: 2007/10/08 00:25
- dreamsofaz1r
07 Oct 2007 22:09
Yes and no. The wheels can be used, but you need a new set of bastard sized bearings(I JUST went through this same thing trying to put kz1000 wheels on a 650) and the bearings cost an arm and a leg.
You can have them chromed also. Again, not a cheap route to take.
- kz650csr81
08 Oct 2007 09:18
sorry having issues with the qoute option
Post edited by: kz650csr81, at: 2007/10/08 12:21
- kz650csr81
08 Oct 2007 09:25
JMKZHI wrote:
so if I changed the entire swingarm I shouldn't have to worry about the bearings right??? the chroming is the easy part I got the "hook-up" from a friend intown on the cheap...
For the mag wheel conversion: Recent rear brake topic
81-83 KZ750-Ltd-4 (KZ750-H2/H3/H4)...(& maybe the 80 H1 model as well).
The Ltd-4s have the same frame as the 650-CSRs & share a number of parts including the exhaust system. The rear swingarm & wheel should be a direct swap. You'll have to fab a rear master cylinder bracket.
