rear brake question
- jccwall
rear brake question
04 Oct 2007 07:59
have an 81 kz650 h1 csr.
question, diagram shows rear brakes as being drum brake setup. this bike actually is rear disk. 1st is could it have come this way? second, if not how can i find out how to get replacement parts. ie. rear disk, pads and master?
thanks,
jim
Post edited by: jccwall, at: 2007/10/04 11:00
thanks,
jim
- The Gringo
- ¡Usted no necesita otra motocicleta!
Re: rear brake question
04 Oct 2007 08:25
I've got an 81 650 CSR as well and you are correct they are supposed to come equipped with a rear drum brake and spoked wheels as well. I suspect your bike might have a mag rear wheel? What do you have for a front wheel setup, a mag with dual disc or a spoke wheel with a single disc? The 650 CSR and the 750 LTD's share a common frame so someone may have swapped the 750 wheel and brake setup onto your bike. Also if you have any pics, that may help us nail down what you have.
Andy
Akron, Ohio
80 Z-1 Classic-Sold
84 GPZ1100
79 KZ 1000 LTD
78 KZ 1000 A2
77 KZ 1000 LTD-Sold
KZ 550 times 2 80 440LTD-Sold
Akron, Ohio
80 Z-1 Classic-Sold
84 GPZ1100
79 KZ 1000 LTD
78 KZ 1000 A2
77 KZ 1000 LTD-Sold
- jccwall
04 Oct 2007 09:26
it has a mag wheel on front and a dual disk but only one caliper.
- The Gringo
04 Oct 2007 10:02
Ok odds are good that some PO just swapped the parts off a 750 LTD onto your bike. The 650 CSR did not have a mount for the second disc on the RH side of the fork lowers. My guess is that someone put the rear disc setup as well as the mag wheel from a 750 LTD on your bike. Hard to say for sure without pics, but that would be my best guess.
Andy
Akron, Ohio
80 Z-1 Classic-Sold
84 GPZ1100
79 KZ 1000 LTD
78 KZ 1000 A2
77 KZ 1000 LTD-Sold
Akron, Ohio
80 Z-1 Classic-Sold
84 GPZ1100
79 KZ 1000 LTD
78 KZ 1000 A2
77 KZ 1000 LTD-Sold
- jccwall
04 Oct 2007 15:54
actually there are mounting tabs on the right lower fork. just no caliper. wish i could post pics on this one. will see if i can come up with a camera to do so.
