sportster shocks/kz1000e
- rckz
03 Oct 2007 22:03
Just bought a set of sportster shocks. I paid a bit of a premium 'cause these had black springs and I wanted 'em. Length is ~13.25" (about .25 inches on the short side) but that shouldn't be too big of an issue, especially if they're stiffer, which I expect them to be. The bushings on the harley shocks have an ID about 13.65mm, whereas the mounting posts on the KZ are 14mm. I thought about swapping bushings, but the OD of the KZ bushings is too big to fit in the HD shocks. Plus, the old bushings are beat. Now I plan on drilling out the HD bushings to ~14mm. The OD of the metal part of the bushing is about 16.5mm, so there should be plenty of material there. The last concern is that the mounts on the HD shocks are about 3/16" wider that those on the KZ shocks. I also don't think this will cause much of a problem since there are enough threads on the mounting posts to make it work.
Just checking to see it all this sounds reasonable to the group, or at least to anyone who has made this swap. It's not going to be a big deal, but from what I had read on the forum about it, I was expecting it to be a bit more straighforward.
- DrWhizBang
Re: sportster shocks/kz1000e
04 Oct 2007 05:18
That's all I did (drilled out the Sportster bushings). Although I actually used a grinder to take some depth out of the bushings. I made them mostly flush with the eyes.
KZ650C2 w/810CC in Saint John, NB
-- a sleeper, methinks.
- wiredgeorge
04 Oct 2007 06:39
When you buy Progressive Suspension shocks, they list them by application but the eyes are generic. A "bushing kit" is supplied to make most any shock work on most any application. They do sell the bushing kit and these come in handy when mounting odd shocks to a bike... I have bought several of these kits over the years just for this purpose.
- RonKZ650
04 Oct 2007 06:48
I'd think the sportster shocks would be much lighter duty than the KZ1000E shocks myself.
KZ1000E- Close to 700lbs made in Japan
Sportster- 400-500lbs made in China??? At least Harley shocks were all Chinese last I heard. Are these Harley shocks any good? Big surprise to me if they were.
- JMKZHI
Last edit: 03 Dec 2008 07:49 by JMKZHI.
- CruisingRam
04 Oct 2007 19:05
dude- the 883 Sporster is 574 pounds DRY- more like 630 without fuel!
An old KZ1000 wieghed 518 pounds, dry- closer to the Sportster's dry wieght!
Harley's wieght lots and lots dude!:laugh:
1975 Z1 B 900- soon to be heavily modded
Pahoa, Hawaii is my new hom
I am working hard to save up the shipping money to get my shop opened here in Hawaii
I hate electrical stuff.
- KZ_Rage
- Kentucky Bourbon Barrel Ale
04 Oct 2007 19:27
An "E" will go around 600-610lbs. with all fluids in it. That is for a stock non-fairing, saddlebag model, it will weight more if it is dressed.
When you mount the shocks put the right side one on first and tighten the bottom mount first. Note the amount of gap between the shock mount and the frame on the top stud mount. Don't just tighten it down or you have jacked the shock into an angle and either it will bind enough to notice in washboard roads or it will cause the shaft seal to start to sideload and leak. You'll have to come up with a spacer to shim up the difference.
Good time to check the swingarm bearings for play or "notches" in their movement, too.
1979 KZ1000E1 SOLD!
1984 KZ550F2 SOLD!
2006 ZG1000A6F (Totaled)
2001 ZRX1200R (Sold)
1984 KZ550F2 SOLD!
- RonKZ650
04 Oct 2007 19:45
CruisingRam wrote:
I'll check out some magazines and get the stats one of these days. All I know is I have a KZ1000E and it's one brute of a bike to put it mildly. If a 883 Sportster weighs more than it, I'll be more than mildly surprized.
Update: I searched online and the Harley does weigh like 550 dry. Call me surprized. I think a KZ1000E will still beat it out in the weight department, but not near the margin I thought. The shocks should work out pretty good actually.
Post edited by: RonKZ650, at: 2007/10/04 22:50
- flht1997
04 Oct 2007 19:54
A new sportster will go about 580-590 ready to go, which i would think could make the shocks good for mabey up to a 650. if you are going to put them on a 1000 i would look for a set of Dyna shocks, Sport if you can find them. the main reason i think the sportster one come up so often is the shorter people putting on the "low" ones. i have a set on one of the 400's and they work well enough. i would not pay more than 20 dollars for a set though. if they want more, just wait another set will come along.
Matt Milwaukee, WI
75' KZ400, (5) 78' KZ400, 76' KZ 750, 78' KZ650
78'CB750F, 78' CB550K
89' BMW R100RT
05' H-D Electra Glide
06' KLR650
Do it right or don't bother doing it at all.
89' BMW R100RT
06' KLR650
- liliysdad
05 Oct 2007 09:20
I have a set of Sportster Hugger shocks on my KZ1000P, and they work great.
- CruisingRam
05 Oct 2007 15:22
RonKZ650 wrote:
I pulled those specs right off www.bikez.com
H-D's lumps are very, very heavy compared to japanese models- even older ones.
H-Ds are pigs man!
CruisingRam wrote:dude- the 883 Sporster is 574 pounds DRY- more like 630 without fuel!
Update: I searched online and the Harley does weigh like 550 dry. Call me surprized. I think a KZ1000E will still beat it out in the weight department, but not near the margin I thought. The shocks should work out pretty good actually.<br><br>Post edited by: RonKZ650, at: 2007/10/04 22:50
H-Ds are pigs man!
