Drive chain
- BoZ650
- 77 KZ650 with 4 to1 and pods,Dyna Coil and Dyna S
Drive chain
03 Oct 2007 14:56
I need to order a new chain.I dont have a ton a cash but I want a decent chain.How can I tell if my sprockets are original or aftermarket.What does 530 mean and will it fit my stock sprockets if indeed they are stock???Any help before I order a chain that doesnt fit???
77 KZ650 With 4 into 1 header,Air pods,Dyna Green coils,Dyna S Ignition and WiredGeorge coil mod!
- arobsum
Re: Drive chain
03 Oct 2007 15:09
530 is the size of the chain and i believe it is stock for a 650.
Re: Drive chain
03 Oct 2007 15:30
'77 KZ650's take size 530 chain with 102 links. Please understand that original chains are endless type (no master link) and require considerable effort to install. If your current chain has a master link, the chain was replaced. Quality replacement chains (example D.I.D.) are available, but make sure the chain you buy has "o-rings." These o-rings help improve chain life and generally don't appear on cheapie chains. You should be able to buy a quality chain for about $60. If you use one with a master link, be sure to install the link facing in the right direction. List price on a genuine Kawasaki chain is about $310. These occasionally come up on eBay in New Old Stock condition (I bought one for $25) but it can be a long wait. Ed
- BoZ650
Re: Drive chain
03 Oct 2007 15:55
So If I buy a 530 chain off ebay or elsewhere it should fit my sprockets?I dont have a chain rivit tool so Ill have to buy a master link!$60.00 sounds good where from?Z1Ent.Has a xtype chain but its 85.00 + the link?I just hate to waste money becuase I need so many other things. Thanks 650ed,and arobsum.
- hwms
Re: Drive chain
03 Oct 2007 16:13
You should always replace the sprockets when you replace the chain. Worn sprockets will be out of pitch and will wear out the chain rapidly.
- steell
Re: Drive chain
03 Oct 2007 16:26
It will cost you somewhere near $145 for the x-ring chain, clip master link, and both sprockets, from Z1 Enterprises.
And that's the cheapest price I have found for a quality chain and sprockets.
Re: Drive chain
03 Oct 2007 18:21
There are a couple on ebay:
cgi.ebay.com/ebaymotors/DID50VA-Motorcyc...dZ1QQsspagenameZWDVW
cgi.ebay.com/ebaymotors/Nickel-530-RK-O-...dZ1QQsspagenameZWDVW
- RonKZ650
Re: Drive chain
03 Oct 2007 20:33
I don't know what kind of chain and sprockets Z1 enterprizes sells so I can't say yes or no to their stuff, but 2 things you want to look for is a decent front sprocket with the stock type hole for the lockwasher, and a decent rear sprocket with stock type look to it. You don't want a cheap sprocket that is flat looking like it was cut out with a cookie cutter. Dennis Kirk sells Sunstar sprockets which are dang close looking to original and I'm pretty sure who made the original Kawasaki sprockets. Get a good 102 link oring or xring (what in the ???? xring is is beyond me, I'm too old I guess). Otherwise you can get the original Kawasaki endless chain frequently on ebay 92057-1232. Right now not a good time, but they come and go for $50-$100. I bought one for $40 a few years ago. It's not hard to install the endless, you need to remove the swingarm, which trust me, needs clean and lube anyway.
- racer54
Re: Drive chain
03 Oct 2007 20:52
Just remember...this is not an area you want to cheap out on. You get what you pay for. This isn't an area where you want to "get by". Better to wait a little longer and get a quality part. I agree...change your sprockets when you get the chain.
