Z1 900 Center Stand re-moval
  • oldkaws4ever
  • oldkaws4ever's Avatar Topic Author
  • Have no regrets...... You only live once.
28 Sep 2007 19:23
#173404
Ok I went to put on an old 4 into 1 bassani header, but i see i have to remove the centerstand. I kept looking and looking, does anybody here know how to remove the centerstand? Thanks
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
  • kzdev1360
  • kzdev1360's Avatar
Re: Z1 900 Center Stand re-moval
29 Sep 2007 10:37
#173489
its held on by a big wrist pin. remove the spring and then remove the pin and it should come right off.
2006 Gsxr 1000
1976 Kz900 LTD
1977 Kz650 (720 motor, andrews cams)
  • patmann
  • patmann's Avatar
01 Oct 2007 06:45
#173922
You'll want to unhook the spring FIRST.The HARD part is getting that dang two part spring off without destroying your knuckles or the spring:S
I found a BIG set of curved long needle nose pliers helps.
There are TWO SHOULDER BOLTS that hold it on. You'll have to follow the center stand up to the mount to find them if it's dirty under there ( aren't they all ? ). . Once you get them unscrewed from the threads, then pull them out. They are about three inches long ( total ) and about as big around are a mans finger. The threaded part is only about half that size, and only an inch long.
Good luck!
A Kerker would sound and look better;)
Pat
www.powersportspro.com/pages/parts/viewbybrand/9/Kawasaki.aspx
CRAP :angry: I need my son to help me with this computer stuff:blink: Go to the link type in your bikes info ( year, cc, ect ) then detail down to "footrests, stands and pedals" it's item #21.
Post edited by: patmann, at: 2007/10/02 10:05
1974 900 Z1 modified to look like a LTD , some engine mods. But I still have all the original parts.
1977 1000 project bike
1972 H1 project bike
If pro is opposite of con, then what is the opposite of progress?
01 Oct 2007 07:05
#173927
I found a BIG set of curved long needle nose pliers helps....
Vaguely recalling technique of pushing pennies between spring coils while expanded to maintain spring length when relaxed. Might try this while spring stretched out with bike on center-stand. Leave pennies inserted and push bike off center-stand. Spring should stay expanded and be more easily removed. Same for replacing spring when reinstalling center-stand. :)
Warning: Above recollection is old and may be a mirage :huh: , or could be thinking about some other spring :unsure: :)
Post edited by: Patton, at: 2007/10/01 10:07
  • patmann
  • patmann's Avatar
01 Oct 2007 07:13
#173928
Warning: Above recollection is old and may be a mirage :huh: , or could be thinking about some other spring :unsure: :)<br><br>Post edited by: Patton, at: 2007/10/01 10:07[/quote]
Warning: The following are also related to old age.
I too remember something like that.. but for the life of me I can't remember if it worked..Sure sounds like it should. I think I might have maybe tried it...now what were we talking about??? Is lunch ready?? :whistle: :pinch: :whistle: ;) :P
Post edited by: patmann, at: 2007/10/01 10:13
