What a score! and fork question
  • tobiism
  • tobiism's Avatar Topic Author
27 Sep 2007 21:22
#173273
My new KZ1000P forks for the 750 twin project.
$30! The early 18" 4-bolt mags were $60 with drilled rotors and axles, sprocket, sprocket carrier and cush drive. My 4 piston Nissin calipers will fit like a champ with this setup. I'm stoked!
Now for my tech question, are the schreader valves worth anything on these forks? Do they help with preload or dampening?
Does anyone have a 1000P front axle with nuts they'd like to get rid of?
Thanks,
Matt
  • tw..
  • tw..'s Avatar
Re: What a score! and fork question
28 Sep 2007 05:18
#173301
I'm almost certain I have a 1000p axle with nuts. I'll take a look when I get home. If you don't hear from me by Sunday send me a PM to remind as a reminder.
2-1976 KZ900 A4
1995 KZ1000 Police bike
1978 Z1R
  • guitargeek
  • guitargeek's Avatar
  • Elitist, arrogant, intolerant, self absorbed.
28 Sep 2007 08:05
#173312
Spring preload? Rebound damping?
I think you might be expecting too much.
The Schrader valves are for putting air into the fork tubes. That's it.
The good news is that by increasing the air pressure you could potentially get an effect similar to what you describe. You'll definitely want to purchase or fabricate an air balance tube.
Congrats on the great deal!
1987 KZ1000-P6 "Ponch"
1979 GS1000 "Dadzuki"
  • Fossil
  • Fossil's Avatar
28 Sep 2007 10:07
#173323
An upgrade for the GPz forks that use air is to install progressive springs with correct spacers and not use any air pressure, should improve your forks.
  • tobiism
28 Sep 2007 15:50
#173367
Thanks!
From what I've just read on another site, it appears that the added air pressure aids in ride height adjustment and preload, but excess air pressure can increase the chance of blowing out fork seals. I'll probably just not use them.
Thanks again,
Matt
Post edited by: tobiism, at: 2007/09/28 18:55
  • tobiism
28 Sep 2007 16:22
#173370
Thanks! I look forward to hearing from you!
  • tw..
  • tw..'s Avatar
07 Oct 2007 13:58
#175093
I'm back and sorry for the delay. I got the front axle with axle nuts that your looking for. If your still looking send me a PM and we can discuss price.
Tom
2-1976 KZ900 A4
1978 Z1R
