Need help!
- whatever
Need help!
27 Sep 2007 13:29
I've got a '77 kz1000 with mag wheels that I just had the tires replaced on. The rear tire had a tube and two beadlocks. The mechanic broke one of the beadlocks when changing the tire. The tire went flat the day after and I just took it back to them. They called and said that the other beadlock broke which is what caused the tube to go flat. They said the beadlocks are $92 a piece. They won't pay for the beadlocks because they said they were old and that's why they broke. What do I do? Is there anywhere I can get beadlocks at a reasonable price? Is there anyway to convert the wheel to where I don't need a tube (I asked the guy at the shop if he could put a valve stem in the hole and plug up the other two, but he said it wouldn't work)? Does anyone have some spare beadlocks I could buy? Should I just try and find a nother wheel? I don't have an extra $184 lying around because I just got married and I'm in college, so any suggestions would be great. Thanks
Jon
Jon
- Wildh2oskier
Re: Need help!
27 Sep 2007 14:17
Check e-bay for the whole tire with a rim and beadlocks. You can pick one of those up for way less than the cost of getting the new beadlocks.
- StreetfighterKz
Re: Need help!
27 Sep 2007 15:45
It sounds like you have a sucky shop who doesn't know how to lookup anything aftermarket. Try this link
www.speedsupplies.com/accessorylistingde...purch.asp?item=13292
Part #864-3508 should do the trick. Perhaps someone else can back me up or correct me. It's been a while since I left the shop I use to work at.
later, Doug
later, Doug
1978 z1000 Streetfighter
1976 z900 ‘Stripfighter
1978 z1000 w/RC Turbo
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
1979 z650 Resto-Mod
2018 Z900RS
- whatever
Re: Need help!
27 Sep 2007 15:57
That's perfect. I was looking up beadlocks instead of rim locks, and I guess that's why I couldn't find anything. Does anyone know the standard rim width? I'll probably just call the shop tomorrow and get them to tell me.
Thanks
Post edited by: whatever, at: 2007/09/27 19:00
Thanks
Re: Need help!
27 Sep 2007 16:50
Take a look here. This looks very much like original, although it's aftermarket:
www.americanclassix.com/kawa_reproductions.html
- RonKZ650
Re: Need help!
27 Sep 2007 19:09
Rim locks do not cause flats. You can take both of them off and throw them in the trash if you want. They are not necessary to enable use of the wheel/tire. I use mine just because they are there. How in the heck can you break one of these is my question???
- whatever
Re: Need help!
27 Sep 2007 19:21
My guess is that it was a young mechanic who had never see anything like it before, and he screwed it up somehow. They told me they would replace the tube for free but not the rim locks, and they said they wouldn't put it back together without the rimlocks, so I'm just going to order some cheap ones and avoid spending $184 extra.
- violentvintagecycles
Re: Need help!
28 Sep 2007 16:26
You should tell them if they thought it was that old they should have not done it in the first place and make em pay for it. General rule of thumb since i was like, i dunno, 5? you beak it you bought it! Give em hell.. lol
- RonKZ650
Re: Need help!
29 Sep 2007 07:19
violentvintagecycles wrote:
This is true, but honestly, 30 yr old parts can just fall apart in your hands as they are touched. That being said though, these bead locks are what? Hard rubber with a 8mm stud imbedded in them? How do you break one? Get a hammer out and beat on one, I'd doubt it could be broken. Strange.
- DrRatchet
Re: Need help!
29 Sep 2007 09:40
RonKZ650 wrote:
Does the shop have a powered tire changer? If the kid never even looked at the rim (and why would he? He's maken' $6.77/hr) and stuck the iron in and stomped on the pedel... bang!@#%
