Locked Caliper
  • Skypilot54
  • Skypilot54's Avatar Topic Author
Locked Caliper
26 Sep 2007 20:13
#173091
So, I've developed a problem with a locked front caliper. I have the master cylinder and front caliper off the bike and am preparing for a rebuild. The rear is a drum brake and I already put new shoes on and cleaned up the rest of the rear system.
The inside of the master and caliper (after I popped the piston out) were pretty crappy looking with some nasty looking crud, and I'm sure that's a major contributing factor.
I do have a question. At the bottom of the master there are two holes. One I assume is for allowing fluid from the reservoir to the piston to the system. The second is ... a return? a vent? The second hold in mine appears to be plugged. Should it be open to the piston? Should it be a large an opening as the other hole?
As always, thanks for everyone's help.
  • BSKZ650
  • BSKZ650's Avatar
Re: Locked Caliper
27 Sep 2007 05:05
#173142
yes both holes should be open in the master cyl.
if the caliper is froze, fill it with pb plaster and let it sit, close the bleader and use a rubber tipped air gun, hold it tight and blast away, NOTE: keep fingers away from the piston, and cover it with rags, if not you will not like the results, I know this first hand
77 ltd1000, current rider
76 kz900, just waiting
Re: Locked Caliper
27 Sep 2007 05:13
#173143
From m/c reservoir to piston bore, the supply port is the larger and the relief port is pin-hole size. :)
As signature mentions Frankenbike, are we dealing with stock m/c and caliper? :unsure: :)
  • Skypilot54
Re: Locked Caliper
27 Sep 2007 06:04
#173148
Thanks. Yes everthing is stock.
