GPZ 550 forks vs KZ750F forks of the same year?
- CruisingRam
25 Sep 2007 13:42
I want to improve the handling of the KZ750F in my shop right now, and have a line on some GPZ550 forks, is this swap "worth it"- also- I want to run the same stock rim, so if there are better forks, I want them to be compatable with with these rims (1983 KZ750F)
1975 Z1 B 900- soon to be heavily modded
Pahoa, Hawaii is my new hom
I am working hard to save up the shipping money to get my shop opened here in Hawaii
I hate electrical stuff.
- steell
Re: GPZ 550 forks vs KZ750F forks of the same year?
25 Sep 2007 13:56
I have a set of forks off a 83 GPz550, and they are only 35mm in diameter vs 36mm (I'm pretty sure) for the 750 forks.
Probably the most cost effective way to improve the handling is Progressive fork springs with the proper weight oil.
The time and cost escalates from there.
- loudhvx
25 Sep 2007 21:47
The 81 gpz 550 used 36mm forks. The later gpz 550's used 35mm forks, but with a thicker wall to make them stiffer than the 36 forks.
When I buy spring kits from Works, I buy the ones for a KZ750 (they are 28mm diameter springs).
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
- guitargeek
26 Sep 2007 09:48
If you want to go with a GPz fork, get one from a 1982 GPz750. They swap right in and have an air balance tube, plus a non-offset axle (the LTD axle won't work with them, nor will the fender or brake caliper brackets: different geometry).
Your best bet is to use the fork that came with the bike, put in fresh seals and some Progressive springs and fabricate an air balance tube.
1987 KZ1000-P6 "Ponch"
1979 GS1000 "Dadzuki"
- CruisingRam
26 Sep 2007 11:16
guitargeek wrote:
The forks I have are offset as well!
