KZ750 L3 Fork oil type and level
  • rampage58
  • rampage58's Avatar Topic Author
24 Sep 2007 03:44
#172470
First I want to thank all you for all the help I have got from this site. You helped me replace and adjust my clutch.and do the seals in my forks...But I think I dont have the right amoint of oil All I could get was HARLY oil for SHOWA forks... Please tell me what type of oil ,how much oil and how much air should I have in them....This is the only place I have seen the L3 SPORT
KZ RIDER ROCKS
  • OKC_Kent
  • OKC_Kent's Avatar
Re: KZ750 L3 Fork oil type and level
24 Sep 2007 05:16
#172487
Welcome rampage58,
Air Pressure: DO
    not
use a hi pressure hose. Hand pump only:
The Clymer manual I have says to put the bike on the centerstand and get up to 25 psi in the forks. Do not exceed 36 psi.Ideally it also says to have some type of accessory pressure equalization line installed so both forks have the same pressure. Then it says to bleed off air until you get to your desired psi. The range is 8.5 - 13 psi. Standard is 10psi. Use more psi for high speed/heavier load.
Fork oil:
Dry = 8.4 oz(248cc)
Wet = 7.8 oz (230cc)
Oil level = 12 inches (355mm) Put a thin rod in the top of the fork and measure level from top of fork tube.
Fork oil is checked with forks fully extended and fork spring removed. Use oil grade SAE 10W.
Cashion, OK
78 KZ650 B2 85,000+ miles
