tube repair
- arobsum
tube repair
22 Sep 2007 18:17
has anyone had any luck patching tubes? i bought this
tube from jc whitney and it leaks. the patch kit i bought is useless. i am fed up with these damned tires.
first my kz900 went flat, then a week later my kz1000 went flat. AAhhhhhhhhh......
- KZQ
- Administrator
Re: tube repair
22 Sep 2007 18:25
Yeah, been doing it all my life.
Do a GOOD job on the patch AND Don't pinch it on the way back in!
KZCSI
KZCSI
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
Riders:
Projects:
1985 ZN1300
Re: tube repair
22 Sep 2007 18:33
Tubes are not the place to try to save $$, especially when quality tubes are only $15 each. You'll understand why if you ever have a blowout (I did on my old BSA; it's an unforgettable experience). I’ve looked at numerous tubes from Michelin, Continental, and others and I found that Continental tubes are very high quality and use thick rubber. (I'm not a Continental salesman, in fact, I use Michelin tires.) Patching a leaky tube is Russian roulette as you don't know what speed you'll be traveling when the patch, or a different leak, will open up. Ed
Here are tube sizes:
www.conti-online.com/generator/www/de/en...d_schlaueche_en.html
Here’s one place to buy them, there are other places too:
www.americanmototire.com/
- steell
Re: tube repair
22 Sep 2007 20:39
I will patch a rear tube if it's an emergency,
but if it's a front tube I'll find some other way.
I still remember having asphalt shaved from my arms with a straight razor
the last time I patched a front tube :woohoo:
Post edited by: steell, at: 2007/09/22 23:39
- arobsum
Re: tube repair
23 Sep 2007 07:16
good info. thanks. i didn't pinch the new one. i think it started leaking when i was attempting to seat the bead of the tire. i used soapy water and everything. i had it inflated to around 55-60 psi. it would not seat all the way. i have been fighting these tires for about a month now. really getting sick of it.:sick:
:S
:ohmy: :huh:
- arobsum
Re: tube repair
23 Sep 2007 07:18
KZCSI wrote:
anything you can tell me on a patch kit? a good name brand or anything? any help will be greatly appreciated. thanks.Yeah, been doing it all my life.
KZCSI
- Bluemeanie
Re: tube repair
23 Sep 2007 08:18
For as much fun as it is to remove tire/rim and disasemble/reassemble and reinstall on bike I would always install a new tube! Old mechanics saying..."No one has enough time to do it right the first time, but everyone has enough time to do it right the second time"! Think about it... just my 2 cents.
- arobsum
Re: tube repair
23 Sep 2007 09:43
Bluemeanie wrote:
you are correct. where i live there are no places to buy new tubes, i have to order everything thru dennis kirk or z1 enterprises...etc. so if i can possibly fix this damned thing with a high quality patch i will try it. i just want my bikes back on the road.....For as much fun as it is to remove tire/rim and disasemble/reassemble and reinstall on bike I would always install a new tube! Old mechanics saying..."No one has enough time to do it right the first time, but everyone has enough time to do it right the second time"! Think about it... just my 2 cents.
