Looking for diagram
  • Snakebyte
  • Snakebyte's Avatar Topic Author
Looking for diagram
11 Jan 2006 03:14
#17212
Does any one have a diagram of a single shock setup for a zx bike? I purchased a zx6 swing arm assembly for my Kz. All of you know that I have to mod the frame for mono shock. Well I have been looking at parts diagrams at buykawasaki and noticed that the lever for the shock has two dog bone looking arms. What are these and where do they go. Does any one have pics of a rear setup like this. I checked the archieves and found some pics but non that realy helped. I'm looking for pics of rear shock setup for mono shock. Detailed pics of mounts for the top of shock for conversion. Like I said I seen some in the archieves but some of them I could not see the pic. but there was a desciption. Looking for ideas.
  • twowheeledterror
  • twowheeledterror's Avatar
Re: Looking for diagram
11 Jan 2006 06:07
#17225
Hope this helps.
If you look at the diagram you'll figure it out. :)
When the swingarm goes up the tie rods pull back and up on the pivot, causing it to rotate from it's axis (where it meets the frame) and compress the shock. :)
Post edited by: twowheeledterror, at: 2006/01/11 09:09
  • Snakebyte
11 Jan 2006 11:57
#17271
Thats what I was looking for thanks a bunch. That helps out a lot. From the looks of it you can raise and lower the suspension just buy getting longer or shorter dog bones. Pretty neat setup.
Post edited by: Snakebyte, at: 2006/01/11 14:57
  • twowheeledterror
11 Jan 2006 12:05
#17274
Snakebyte wrote:
Thats what I was looking for thanks a bunch. That helps out a lot. From the looks of it you can raise and lower the suspension just buy getting longer or shorter dog bones. Pretty neat setup.<br><br>Post edited by: Snakebyte, at: 2006/01/11 14:57
Exactly! :thumbup:
Or, you could get someone to machine you some custom rods that have 2 or 3 settings on each end... and be able to adjust them on the fly with a few tools and the center stand. (Hmm... who would have access to machining stuff for that though? ;) hehehe)
  • rstnick
  • rstnick's Avatar
  • Premium Member
  • Premium Member
11 Jan 2006 17:50
#17322
Check out this site: Project Z
He has pics of his 650 build , showing a mono shock swingarm, brackets and linkages.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2 Project
  • wireman
  • wireman's Avatar
11 Jan 2006 21:38
#17371
that guy seems to do some pretty nice work!
  • Snakebyte
11 Jan 2006 23:41
#17394
Wow thats going to be very helpfull in the future. It looks like he had a couple of different ideas before he was satisfied. Now I have a better idea of what to expect. This is going to take more time then I thought.:blink:
  • twowheeledterror
12 Jan 2006 00:26
#17396
No it won't. I'll share my plans with you. I've been calculating and brainstorming this exact thing for years...
  • 77KZ650
  • 77KZ650's Avatar
12 Jan 2006 12:25
#17508
Is that a newer katana arm on that? If so, how does it compare with the gs1100/1000 arms (length, width ect.) that seem to be quite a popular upgrade? thx
07 MDP Rookie of the Year
  • Snakebyte
13 Jan 2006 02:24
#17640
So whats the ideer:woohoo:
Like I said in another post I would like to do it this summer, but afraid that this will take most of this summer I was thinking of putting it off till november 06. I did find a set of dog bones, rear axle w/spacers, rear adjusters, pivot point axle, rear cush drive, all for $50:woohoo: . Of couse the condition of these parts is yet to be determined as he did not send me pics. yet:unsure: . I went to zx6e.com to find these items Still looking for both chain guards. :pinch:
Post edited by: Snakebyte, at: 2006/01/13 05:27
  • Snakebyte
Re: diagram UPDATED
27 Oct 2006 11:32
#87816
Just to let you guys know whats goin on.
I made a spacer for the swing arm pivot point, so I can use my original kz bolt. I have a mook up frame courtesy of cycle theropy(thank you). The swing arm is in the mook up frame. I grinded some meat off the original tabs in the frame to fit the swing arm. After I mounted it I quikly found out that I needed shorter dog bones for the ecentric and shock to fit. I'll post some pics after they develope.
The last peices I need is the caliper braket from a zx 1995, a spacer for the left side of tire, the cush for the zx rim, sproket for rim, and thats it. When I get those parts I will take the bike to my fathers and get to welding B) .
If any of you guys have any of these parts I need please let me know.
Post edited by: Snakebyte, at: 2006/10/30 12:08
  • z11heaven
  • z11heaven's Avatar
02 Dec 2006 09:23
#96755
hay i dont know if i can help but i perchest a gpz1100 1982 with a mono shock it looks good if u like i could try and send pics of the shock set up it mite help out
