Ebay forks...
- Bluemeanie
Ebay forks...
19 Sep 2007 06:44
Have seen these forks on ebay, no bids. Been relisted twice. Question... are all forks (other than CR,SR,LTD, etc) the same from I believe 78-80? Are there numbers I should check? They appear to be the same as mine. They appear to be in great shape, just needs minor polishing which is a plus for me as I like shiny stuff!
tinyurl.com/2wl3y3
tinyurl.com/2wl3y3
- RonKZ650
Re: Ebay forks...
19 Sep 2007 07:05
Going by the Kawasaki parts lists they use different part numbers for every model. Going by the picture those forks are not a 1977 KZ650B, could be 1978-up B or a 1977-79C. If it is in fact a 1978-up B, the lower forks are the same as your F1, but the upper tubes are not. If it's a 1977-79C fork, neither the lower or the tubes are the same as your F1. What the difference is is hard to say. They all use the same fork seals so tube diameter is the same, so any would probably work just fine.
- Bluemeanie
Re: Ebay forks...
19 Sep 2007 07:38
Thanks Ron... now I'm really confused! :woohoo: I know the 77's had the caliper ahead of the forks? These look correct, mine have the holes for a second caliper (mine is single) hense maybe the different part #. I think lower tubes would be the same, just worried about length and diameter of tubes? Plus worried that he says there from a 77, he does not know which worries me. Anyone else?
- steell
Re: Ebay forks...
19 Sep 2007 08:34
Usually, the difference in the fork tubes is the length. That's been my experience with the 650/750 twins/1000's anyway.
- Bluemeanie
Re: Ebay forks...
19 Sep 2007 13:58
Thanks Steell, soooo still don't know which forks to get. I'm assuming any forks off of a 78-80 KZ650 (no SR, CSR, LTD) should work?
- steell
Re: Ebay forks...
19 Sep 2007 16:23
SR forks will work, but not the CSR.
There is more info at www.rev-um-up.com/fork-tubes-honda-kawaski.htm
I'm only familiar with the 80 and older 650's, so I don't know if any later models will work.
Post edited by: steell, at: 2007/09/19 19:25
- Bluemeanie
Re: Ebay forks...
08 Oct 2007 13:32
I found the specs for 77-79 KZ650 which also match up with some 750's and 900's. Problem is, where do I get "specs" for my forks?? Anyone?
- flht1997
Re: Ebay forks...
08 Oct 2007 14:57
i would think that they would work, and for 10 bucks, i'd take the chance. i was out comparing forks, some of the differences would be location of the fork drain, depending on caliper location, and the fender mounts, either straight or offset. meaning i could take the left fork fron the 750B (front mount caliper) and put it on the right side of the 650 (rear mount caliper) and it would all work, but the fork drain would be on the front, and not the rear.
Matt Milwaukee, WI
75' KZ400, (5) 78' KZ400, 76' KZ 750, 78' KZ650
78'CB750F, 78' CB550K
89' BMW R100RT
05' H-D Electra Glide
06' KLR650
Do it right or don't bother doing it at all.
89' BMW R100RT
06' KLR650
Re: Ebay forks...
08 Oct 2007 15:02
Here's the scoop.... Assuming the forks on eBay are from a 1977 KZ650, they are for a KZ650C1. The "C" models had 2 disk calipers behind the forks. Here's the good news. If you take a look at Kawasaki.com.
www.kawasaki.com/DefaultFrame.aspx?strCo.../VICHOOSEVEHICLE.ASP
and plug in your year and model, you should find that the 1980 KZ650F1 takes part 44006-1031 for the right outer fork leg and 44005-1031 for the left. If you then plug those numbers in under Part Number search, you'll see that they were used for a BUNCH of KZ650,750,and 1000 models from 1977-80. So finding these shouldn't be too difficult because there were plenty of them made. PLEASE check the part numbers with a dealer BEFORE you buy anything because Kawasaki.com (and I) sometimes get things mixed up. Ed
- Bluemeanie
Re: Ebay forks...
08 Oct 2007 15:09
Thanks 650ed, I went there and got part #'s but did not know you could search! Cool, helps a lot!!
- Bluemeanie
Re: Ebay forks...
08 Oct 2007 15:21
Ok, bear with me... lower outer fork tubes (#44005-1031) fit the following:
· KZ1000-A1 KZ1000 (1977)-->FRONT FORK (KZ1000-A2/A2A)
· KZ1000-A2 KZ1000 (1978)-->FRONT FORK (KZ1000-A2/A2A)
· KZ1000-A2A KZ1000 (1978)-->FRONT FORK (KZ1000-A2/A2A)
· KZ1000-A3 KZ1000 (1979)-->FRONT FORK (KZ1000-A2/A2A)
· KZ1000-A3A KZ1000 (1979)-->FRONT FORK (KZ1000-A2/A2A)
· KZ1000-A4 KZ1000 (1980)-->FRONT FORK (KZ1000-A2/A2A)
· KZ1000-B1 KZ1000 LTD (1977)-->FRONT FORK ('77-'78 B1/B2)
· KZ1000-B1 KZ1000 LTD (1977)-->FRONT FORK ('79-'80 B3/B4)
· KZ1000-B2 KZ1000 LTD (1978)-->FRONT FORK ('77-'78 B1/B2)
· KZ1000-B2 KZ1000 LTD (1978)-->FRONT FORK ('79-'80 B3/B4)
· KZ1000-B3 KZ1000 LTD (1979)-->FRONT FORK ('77-'78 B1/B2)
· KZ1000-B3 KZ1000 LTD (1979)-->FRONT FORK ('79-'80 B3/B4)
· KZ1000-B4 LTD (1980)-->FRONT FORK ('77-'78 B1/B2)
· KZ1000-B4 LTD (1980)-->FRONT FORK ('79-'80 B3/B4)
· KZ1000-G1 Classic (1980)-->FRONT FORK
· KZ650-B1 (1977)-->FRONT FORK
· KZ650-B2 (1978)-->FRONT FORK
· KZ650-B2A (1978)-->FRONT FORK
· KZ650-B3 (1979)-->FRONT FORK
· KZ650-F1 (1980)-->FRONT FORK
· KZ750-B1 (1976)-->FRONT FORK (KZ750-B3/B4)
· KZ750-B2 (1977)-->FRONT FORK (KZ750-B3/B4)
· KZ750-B3 (1978)-->FRONT FORK (KZ750-B3/B4)
· KZ750-B4 (1979)-->FRONT FORK (KZ750-B3/B4)
· KZ750-G1 LTD II (1980)-->FRONT FORK
- Bluemeanie
Re: Ebay forks...
08 Oct 2007 15:24
But hear is what #44013-1027 inner fork tube matches up with:
Looks like my inner fork is exclusive to my bike only!!?? Damn, I need to do some more checking. I think diameter is the same. According to another (Thanks steele) website, some tubes are 23' long and some are 24' long. MY HEAD HURTS!! :woohoo:
Post edited by: Bluemeanie, at: 2007/10/08 18:27
Post edited by: Bluemeanie, at: 2007/10/08 18:28
