Changing front fender...
- savedrider
- 1975 Z1-B 900
10 Jan 2006 16:59
Is it possible to change the front fender without dropping the front wheel? I know I've taken the fender off before after having the wheel off, but was just wondering if it can be done without pulling the wheel?
I'm not at home to take a look right now, but if my memory serves me correct there is not enough room to get a wrench on the bolts with the wheel in place.
Thanks
Thanks
Get right or get left! <*{{{><
- dkmk
Re: Changing front fender...
10 Jan 2006 17:44
Not completely sure, but I think I took it off with the wheel in place, but ended up taking the wheel off because it such a PITA, I figure the ratio of tire removal time : stress reduction was worth it.
Northern Ontario
Zapp: "Kif, I'm feeling the Captain's Itch."
Kif: "I'll get the powder, sir."
- BohicaBob
- rstnick
10 Jan 2006 18:28
It can be done on the 650 with not too much trouble. The wheel is in the way somewhat, and you need to use an open end wrench. I'm not sure of the 900 though as I've never worked on one.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
- savedrider
- 1975 Z1-B 900
11 Jan 2006 15:47
Thanks for the help! I got my new fender on today without removing the wheel. The hardest part was getting the rear bolts started when bolting it back on.
Thanks again for the responses.
