1978 KZ650 front wheel compatibility
- outaline
14 Sep 2007 15:46
Hi
Apologies if this is a dumb question but I got a front rim with a flat spot and I'm looking around for a new rim/wheel. Other than the diameter, is there another measurement I need to look for? Basically I want to know if I can look for other makes like honda etc. for a wheel that fits.
Thanks!
Thanks!
- jjdwoodman
- Live free, or die.
Re: 1978 KZ650 front wheel compatibility
14 Sep 2007 16:45
Are you looking for a particular style? Or just something cheap? Mag or spoke? The KZ 550 has mag wheels that will bolt right on to a 650B but not a C or D... If you have a 650 b, I have a front spoke wheel that will fit it, but it needs a tire.
77 650b
81 550 Mostly there
83 ZN1300 Voyager
81 550 Mostly there
83 ZN1300 Voyager
- outaline
15 Sep 2007 00:29
My model is a 650b.
I don't really have a preference. I might be interested in the spoked wheel you have - don't need the tire. Is it fairly true?
my email is koids@hotmail.com if you don't mind send me a pic and a price.
Thanks!
Thanks!
- The Gringo
- ¡Usted no necesita otra motocicleta!
15 Sep 2007 04:18
jjdwoodman wrote:
I just went and checked and the 550 wheels will not bolt on a 650 B or C. The 550's use the leading axle style of fork so their axles are a smaller diameter than the 650 B & C models. You can use the 550 front mag on a CSR though because they have the leading axle forks.
Andy
Akron, Ohio
80 Z-1 Classic-Sold
84 GPZ1100
79 KZ 1000 LTD
78 KZ 1000 A2
77 KZ 1000 LTD-Sold
KZ 550 times 2 80 440LTD-Sold
Akron, Ohio
80 Z-1 Classic-Sold
84 GPZ1100
79 KZ 1000 LTD
78 KZ 1000 A2
77 KZ 1000 LTD-Sold
- jjdwoodman
15 Sep 2007 06:56
Thanks, Gringo!
I've swapped out rears on those before and just assumed the fronts would too. good to know!
My spoked wheel is pretty clean and is serviceable, just last time I bought tires they had rims already attached. I'll try to post a pic here if I can borrow a digital cam. It does have some light surface rust in a few spots, but I think it's better than average.
$15 and you pay shipping, but I can pull the tire to drop the weight some. I'll just throw the tube in the box.
77 650b
81 550 Mostly there
83 ZN1300 Voyager
81 550 Mostly there
83 ZN1300 Voyager
- outaline
15 Sep 2007 08:16
jjdwoodman, sounds good.
I just sent you an email.
- Lenwoodbluz
18 Sep 2007 02:14
Can you swap the csr forks with the forks on the kz650b to get the 550 mag front wheel to bolt on?
I have a chance for a set of 550 mag wheels and I would love to put them on my kz650.
Basically, what is my easiest method to get mag wheels on my kz650.
thanks a ton. Lenwoodbluz
5 Seconds Hating is 5 Seconds Wasted!!!!
- Lenwoodbluz
18 Sep 2007 02:16
by the way. it is a 1978 kz650B
just thought I'd add that in
