Front and rear fender swapability
  • oldkaws4ever
  • oldkaws4ever's Avatar Topic Author
  • Have no regrets...... You only live once.
12 Sep 2007 22:46
#170296
Hello all, i was wondering if it is at all possible to use the front and rear fender from a 1977 kz 650b on a 1974 Z1A 900?. I would think you could since the front on both is 19" and the rear is 18". If anybody could let me know i appreciate it. Thanks :)
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
  • The Milkman
  • The Milkman's Avatar
Re: Front and rear fender swapability
13 Sep 2007 05:36
#170321
It may not be a direct swap, but, with a little work you can get anything to fit anwhere,,,;) ;) ;)
Ride safe
  • Mark Wing
  • Mark Wing's Avatar
13 Sep 2007 07:28
#170335
On the front you'll have to slot the holes, I had to slot the holes on a Z1 fender that I put on my 650.
Mark
Yorba Linda Cal.
