Front brake lever replacement
  • road_rascal
  • road_rascal's Avatar Topic Author
10 Sep 2007 15:31
#169853
I replaced the (bent) front brake lever due to a small tipover in the garage. Now, after about 20 mile ride the front brakes are dragging. I believe this is because the new lever is not exactly the same as the OEM lever (Parts Unlimited lever from Dennis Kirk). Can I solve this problem by rebleeding the brakes so the master cylinder can accomodate the new lever? Or do I have another problem? I replaced the front brake lines and bled the system a few months ago and they worked fine, using the old lever of course. Thanks for the help.
  • rstnick
  • rstnick's Avatar
  • Premium Member
  • Premium Member
Re: Front brake lever replacement
10 Sep 2007 18:42
#169887
Does the new lever have some free play? It should not make contact with the MC plunger (?). If there is no free play, take off the lever and file off a bit of material where the lever contacts the master cylinder, to give it some free play.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
  • road_rascal
10 Sep 2007 19:26
#169903
Very slight freeplay. I was thinking about shaving off some material but I wanted to get some input first. I bought two so I guess I can experiment with one. Thanks for the tip.
11 Sep 2007 03:52
#169953
road_rascal wrote:
Very slight freeplay....
Slight freeplay should be just right. Additional freeplay won't help as master cylinder piston is already in fully relaxed position.
Before filing anything, suggest checking for brake drag with lever removed. :)
  • road_rascal
12 Sep 2007 09:45
#170157
The front brakes do not drag at all with the lever removed (and they don't drag with the old lever either). One thing I did notice with the new lever is that the rear brake light stays on because the brake light switch extends too far with the new lever. Is there a way to adjust that switch? I may have to figure out a way decrease the gap between the lever and the switch. I'll probably end up having to buy a stock (read $$$OEM) lever.
