Rear disc conversion
- BoZ650
- 77 KZ650 with 4 to1 and pods,Dyna Coil and Dyna S
08 Sep 2007 09:51
Ok I have a 77 kz650 and im changing to rear disc brakes.I have most of the components needed,however I dont have a spot to bolt rear master cylinder on!Should I weld a gusset or do they have a bracket available?Oh yeh,I also need push rod from master cylinder to rear brake pedal.Can this be made?THANKS GUYS!!!
77 KZ650 With 4 into 1 header,Air pods,Dyna Green coils,Dyna S Ignition and WiredGeorge coil mod!
- OnkelB
Re: Rear disc conversion
08 Sep 2007 10:07
I made my own bracket that fits the two upper rear engine mount bolts - just used longer bolts and also used a couple of extra nuts as spacers to align the mc with the brake pedal. Took a couple of trys to get it right but it wasn´t too hard. I used the mc, brakes and rear wheel off a GPz900R as well as swapping in a Zephyr 750 swingarm.
Here are some pics:
Post edited by: OnkelB, at: 2007/09/08 13:53
Here are some pics:
77 KZ 650 B1, 82 GPz 1100 B2.
- OnkelB
- OnkelB
- BoZ650
08 Sep 2007 10:23
Great Idea thank you!
- BoZ650
08 Sep 2007 10:23
- arobsum
08 Sep 2007 16:35
thats a good job. i may have to try that on my kz900.
- BohicaBob
08 Sep 2007 17:55
I made a metal bracket, after I made and tested a heavy duty cardboard version, to mount a '82 KZ1100 rear brake master cylinder to my '73 Z-900 frame's right rear upper engine mount, all in my effort to replace the stock rear drum brake system with a rear disk brake system.
It took some planning and time but it's doable. See the second link in my signature.
Post edited by: BohicaBob, at: 2007/09/08 20:56
Post edited by: BohicaBob, at: 2007/09/08 20:57
