mag wheels
- jus1975
- www.tripleaperformance.com
mag wheels
07 Sep 2007 08:25
Is there a 17" or smaller mag wheel? I thought I say a 16" rear wheel. Can a rear wheel be used on the front with a single custom brake disc. I dont have one to look at but it seems it could be possible.
- galaxian
Re: mag wheels
07 Sep 2007 08:30
I suppose the rear can be used up front but there are things to remeber about this.
1. the spacing on the drive side will have to be addressed, since you will not be using the cush drive.
2. If the offset of the disk is the same as the front wheel then no problem there.
3. Speedo drive can be installed onto the wheel but again spacers, spacers, spacers.
But why it would he hiddeious...
There are plenty of wheels out there better suited for this and will look much nicer. I would just go with a 17 from a gsxr, cbr or what ever wheel you fancy and you will have greater tire selection as well.
Just a thought.
Post edited by: galaxian, at: 2007/09/07 11:31
Just a thought.
1977 KZ1000A1, 1979 KZ650 C3
