Bent fork or triple tree?
  • vach
  • vach's Avatar Topic Author
04 Sep 2007 18:17
#168570
Hey guy's.. I just put new roller bearings in my head set.. When I took the bolts out of the upper triple tree the both broke and I couldn't get them out, so I bought one off of e bay.. The bearings I had were ball bearings in the triple tree and I was missing 3 of them for a while, so the bike was always loose a bit.. Now that it's all I have to lean left to keep it straight. The bike has been dumped quite a few times but I want to make sure that I know what's wrong before I go buy stuff. What is the best way to tell if forks are bent slightly?Could it be the upper tree? If one of the forks was weaker than the other could that make this happen? Thanks for all the help.
Kevin
1979 kz650 B. Chicago, Illinois
  • JMKZHI
  • JMKZHI's Avatar
Re: .
05 Sep 2007 04:30 - 03 Dec 2008 09:40
#168631
del
Last edit: 03 Dec 2008 09:40 by JMKZHI.
  • BSKZ650
  • BSKZ650's Avatar
Re: Bent fork or triple tree?
05 Sep 2007 05:01
#168633
prior to taking it apart I would put the bike on the center stand and chock the front wheel, the measure both sides of the forks to the ground, and at diffrent points on the frame to see if it is in line, you can also attach a plumb bob on both sides of the bike for referacnce points
77 ltd1000, current rider
76 kz900, just waiting
  • vach
05 Sep 2007 16:51
#168805
Thanks guy's.. I just wish I had checked em when I had em off the bike..;)
