triple trees
  • drphilgood
  • drphilgood's Avatar Topic Author
triple trees
02 Sep 2007 19:02
#168098
Will 1978 kz650 triple trees fit a 1980 kz750 neck?The races are still in the 750 neck and im using all original hardware from the 650.Thanks for any help
Phil
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
Re: triple trees
03 Sep 2007 05:22
#168149
i cant say if it is a dierect fit, but lots of guys take trees off new bikes and press out the bottom tree stem andswap them with the kz stem. the kz stems ar a smaller diameter so a sleave needs to be made to go around the bottom befor it can be pressed into the new tree.
So the answer is yes but it may take some work.Or u may be lucky and be able to get away with a bearing swap. Hope this info is of some help. Good luck.B)
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
  • drphilgood
Re: triple trees
03 Sep 2007 17:33
#168305
figured it out the guy welded my neck upside down on my frame.Thanks for the info
