Chassis swap questions (KZ750 twin)
- tobiism
02 Sep 2007 14:17
Hello, I've tried to search but haven't found the answer I'm looking for. Will the KZ750 twin engine fit into any of the other KZ/GPZ 4 cylinder chassis'?
Thanks in advance,
Matt
Thanks in advance,
Matt
- steell
Re: Chassis swap questions (KZ750 twin)
02 Sep 2007 15:14
If you are willing to do a whole lot of work it will
The 750 twin motor is a lot taller than the 750 four motor, so you would have to raise the frame main tube.
I tried it once.
I tried it once.
- tobiism
- btchalice
03 Sep 2007 10:49
that plus the ezhaust will hit the downtubes.
i did the swap the other way and had to cut and widen the downtubes
Terry Meyer / Wichita KS
76 kz900 w/1000 motor TWZTD
- tobiism
03 Sep 2007 23:11
btchalice wrote:
So you put a 4 cylinder into a twin frame? What size engine did you use?
- btchalice
05 Sep 2007 05:26
i used a 77 1000 in an 82 csr750 frame
