Need your welding advice
- Kellen79_650
02 Sep 2007 02:46
Hey guys, it's about time I bought my own welder and quit fooling around. All the migs that I have used have been huge 250 + amps, so I am having a hard time deciding what to get. I don't want to spend a ton of money, but there seems to be a very large disperity between the price of Migs up to 180 amps and migs 180+. Do you guys think I would be ok working with a 175 or 180 amp. Don't see myself welding anything thicker than 1/4" and most of the time will be less than that. As always, thanks for your help.
"In the beginning of a change, the Patriot is a scarce man, Brave, Hated and Scorned. When his cause succeeds however, the timid join him, for then it costs NOTHING to be a Patriot."
~Mark Twain
~Mark Twain
- PLUMMEN
Re: Need your welding advice
02 Sep 2007 07:29
ive got a hobart handler 175 wirewelder that i use when i need to weld light to medium stuff that works fine,when i want to build a bridge ive got an old ac/dc stick welder;)
- caffcruiser
02 Sep 2007 09:47
If you're only doing bike stuff a small welder, even UNDER 175-180 amps is plenty. Here's a little secret too.... small welders CAN weld thicker material. The problem is that the heat output isn't enough to sufficiently heat the parent metal for penetration.
So how can you do it? EASY!
Get a small oxy acetylene setup and preheat the parent metals over 500* and then use a small welder. The weld will be plenty strong.
I know someone who has built more than one bike and an entire hotrod, chassis and all, with a 100A 110 welder from Lincoln. This guy has been a pro welder for 35+ years, so he knows his stuff.
Anyhow, if you are looking for affordable with good power, I recommend the Esab MigMaster 203. It's affordable, you'll save money running larger spools of wire, and you'll have adequate power for anything you need to do in a simple, no BS package.
Click on the picture for the information. Good luck!
- arobsum
02 Sep 2007 09:52
i've got the little 110 vac mig unit that seems to work great on the light stuff. not so good on the thicker stuff though. i guess it all depends what you plan on using it for.
- Kellen79_650
02 Sep 2007 21:30
Caffcruiser,
once again, I appreciate your help. You are turning in to the Godfather for my. Don Caffcruiser.
Anyway, I think I have settled on the Hobart Handler 187.
~Mark Twain
~Mark Twain
- jjdwoodman
- Live free, or die.
02 Sep 2007 22:25
I've used that Welder, and had good luck with it. It was in my father-in-law's custom truckbed shop and saw everyday use. good unit.
77 650b
81 550 Mostly there
83 ZN1300 Voyager
81 550 Mostly there
83 ZN1300 Voyager
- caffcruiser
03 Sep 2007 06:10
You'll be happy with that hobart. The feed system is a *bit* wonky, but nothing you'll notice if you're just getting started.
On the PLUS side, parts are ALWAYS available, and usually locally through someone that sells the Hobarts.
Good luck with the welder! Have fun!
- conpewter
04 Sep 2007 08:55
Good discussion here, I'll be getting a welder sometime, though I'm very much a beginner at metalworking.
- CruisingRam
04 Sep 2007 11:44
I have a Millermatic 135. It works on 110, I never use an extension cord, and my power is pretty clean at my shop.
I love it and use it almost exclusively now. I just got a spool gun for aluminum for it as well, cost almost as much as the welder, second hand!
The Millermatic will weld up to 1/4", first pass, with flux core .35 wire.
Anything thicker I use the good ol "freebie" stick welder, and choose my rod for application- I have tons of 6013, so I use that alot. Can't do vertical down or overhead with that rod though- know which rod you need when doing stick welding!
I personally have not seen the need for a larger mig machine at this time.
1975 Z1 B 900- soon to be heavily modded
Pahoa, Hawaii is my new hom
I am working hard to save up the shipping money to get my shop opened here in Hawaii
I hate electrical stuff.
