FORK SPACE
  • JAILBAIT
  • JAILBAIT's Avatar Topic Author
FORK SPACE
24 Aug 2007 08:50
#166070
How much gap should there be between the top of the fork boot and the bottom of the triple tree? 1977 kz1000
  • PLUMMEN
  • PLUMMEN's Avatar
Re: FORK SPACE
24 Aug 2007 09:12
#166075
it verys by how long your fork tubes are and how good your springs are.i used to slide mine about 3/4" above the top triple tree to lower the bike,then i found out 650 tubes are same diameter but shorter to begin with;)
  • dutchz
  • dutchz's Avatar
Re: FORK SPACE
24 Aug 2007 10:07
#166084
Jailbait, I think wireman's right here. It's not really exact science but maybe a KZ1000 owner can pitch in. I assumed all Z1-KZ650-KZ900-KZ1000 36mm forks were the same length, but I guess that assumption is wrong.
I'm messing around with my forks myself, the PO had them set up with some funky dampers so I am not sure if the tubes are stock either. The forks I have on my Z1 measure 31" from the fork cap to the center of the axle (no load). It would be nice if we had overall length of different model forks. Anyone wanna pitch in? :whistle:
Post edited by: dutchz, at: 2007/08/24 13:16
Post edited by: dutchz, at: 2007/08/24 13:21
1974 Kawasaki Z1
Stock front hub and rear axle.
  • PLUMMEN
  • PLUMMEN's Avatar
Re: FORK SPACE
24 Aug 2007 10:21
#166087
ive got the forks from my turbo bike sitting here,they are about 30 3/8- 30 1/2 to center of axle.the lower legs were from a 77-78 1000,im not sure if the tubes were from a 1000 or a 650 though.B)
  • JAILBAIT
Re: FORK SPACE
24 Aug 2007 10:25
#166088
basically i am trying to figure out if the previous owner of my bike lowered the forks. He did a lot of shady things to get it to look like a drag bike, like cutting the swingarm at the pivot and putting in a 3" block to extend it. He also cut 1" out of the back bone and heated the tubes up and bent the neck back to rack it also. So I am just trying to get it back to a safe working order. I will try and get ,some pics this weekend while I am working on it to show everyone the not so right way to make a drag bike.
  • dutchz
  • dutchz's Avatar
Re: FORK SPACE
24 Aug 2007 13:43
#166115
I guess we're in the same boat huh, haha. 31" was a rough, to be exact it's 30 5/8 from the top of the tube (underneath the fork cap) to the center of the axle.
Oh boy. Well it appears you can get an idea of approximate fork length now, should be right around 30.5"
1974 Kawasaki Z1
  • steell
  • steell's Avatar
Re: FORK SPACE
25 Aug 2007 06:40
#166214
I think the difference in length is due to the length of the fork inner (upper) tubes.
There is a chart of fork tube lengths (and diameter) for the KZ's HERE
Post edited by: steell, at: 2007/08/25 09:40
  • dutchz
  • dutchz's Avatar
Re: FORK SPACE
25 Aug 2007 08:41
#166228
Thanks Steell, that's helpful info. Besides tube length the dampers and springs influence overall length too.
1974 Kawasaki Z1
