kz1000 swingarm to fit kz650?
- BoZ650
- 77 KZ650 with 4 to1 and pods,Dyna Coil and Dyna S
24 Aug 2007 04:41
O.K.first of all I want to thank you guy for all the previous help! This site is great and saves me from making mistakes that most of you have gone through!Cant thank you enough!
Once again im in need of advice.Im starting the building process of a 77 KZ650B.I want a rear brake set up.I got my hands on a KZ1000 rear swing arm set up for rear disc.I also have wheels from a rear disc bike(mags).Should I just fab-up my 650 swingarm with the parts off the 1000 swingarm,or will the 1000 swingarm be the better deal???The 1000 seams to be longer and wider at the frame.
any body care to expand on this!
Post edited by: BoZ650, at: 2007/08/27 05:38
77 KZ650 With 4 into 1 header,Air pods,Dyna Green coils,Dyna S Ignition and WiredGeorge coil mod!
- btchalice
Re: kz1000 swingarm to fit kz650?
24 Aug 2007 05:16
the 1000 swingarm is about 1.5 inches longer but should be a pretty close fit in the frame.
Terry Meyer / Wichita KS
76 kz900 w/1000 motor TWZTD
- BoZ650
24 Aug 2007 14:37
tried to mock it up today.The front where it bolts to the frame is about a 1/2 inch to long.should I grind the frame a little on each side.The frame has what looks like spacers welded from the factory on both sides where the swing arm bolts in.Or will the kz750 set up bolt right in.
Post edited by: BoZ650, at: 2007/08/24 17:52
- btchalice
24 Aug 2007 17:26
i think the 650 and 750 frames are the same on the 4 cylinders
- ten6
24 Aug 2007 18:09
Ratmeister just did this conversion on his 650 and it went pretty well. He had to take off a little material at the swingarm pivot and a get a longer chain. Other than that he had to fab up a custom "torsion bar" if I have that right. It works well and looks good. If you didn't know what you were looking at you would never know it wasn't stock.
Michigan City, Indiana
Firefighter MCFD IAFF Local #475
(3) KZ650s (1) 1996 Vulcan 1500A (1) 1978 KZ1000 (1) 1986 Yamaha Radian 600
2000 Dodge Ram 4x4
1960 Chevy Bel-Air
2000 Dodge Ram 4x4
1960 Chevy Bel-Air
