rear brake caliper alignment
  • udder
  • udder's Avatar Topic Author
21 Aug 2007 17:46
#165482
ok i have the rear axle bolt in and am looking at everything and it seems ok but when i rotate the tire without the pads in the rear brake disk rubs the rear caliper ever so slightly. it seems to clear at the top or the front of the caliper but hits about 3/4 through the caliper towars the rear of the bike. the adjusters to align the wheel is in the same spot on both sides so it should be straight. any ideas??? major problem or no?
