Pitbull Stands
  • circusnuts
  • circusnuts's Avatar Topic Author
Pitbull Stands
20 Aug 2007 19:30
#165283
Can we use them on the KZs?
I need to suspend the bike so I can send off the wheels to have new rims installed on the stock hubs.
TIA
Phil
  • dutchz
  • dutchz's Avatar
Re: Pitbull Stands
21 Aug 2007 05:38
#165346
Swingarm stand: yes, as long as they have the cup-style attachments (as opposed to the ones that only work with spools).
Front: don't know. It will have to be quite tall, the two front end stands I've seen (not pitbull)were too short to pick the steering head up.
In a pinch: if you've still got the center stand, you can take the rear wheel off then jack up the front with one or two jacks.
Post edited by: dutchz, at: 2007/08/21 08:43
1974 Kawasaki Z1
Stock front hub and rear axle.
  • StreetfighterKz
  • StreetfighterKz's Avatar
Re: Pitbull Stands
21 Aug 2007 09:07
#165389
I think the rear will be fine as long as it has "paddles" and not "forks". I also believe the front to be too short.
I don't have a front stand but I'll tell you how I raise the front. I put the bike on the side stand, obviously. Then take a floor jack, not a bottle jack, and place the pad under the front right peg bracket. I then jack it up no higher than I need to. This is how I swpaped my front end out on my 1000. Works pretty good, just check to make sure the bike isn't slipping of the jack.
Later, Doug
1978 z1000 Streetfighter
1976 z900 ‘Stripfighter
1978 z1000 w/RC Turbo
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
