Is Brake fluid backwards compatible?
- Nelson
17 Aug 2007 23:13
I'm busy fitting an 02 busa rear caliper to my KZ. It takes DOT 4 and the old KZ master takes DOT3.
Can I run DOT4 in the old KZ master?
I think DOT5.1 is compatible with both, but it's hard to find and pricey.
Restoring and customizing a KZ1000. Click here to read about it.
Plated KTM, DR650, KZ1000, Former MC mechanic (eons ago). 40 yrs. of dirt and street.
Re: Is Brake fluid backwards compatible?
18 Aug 2007 05:02
DOT 4 should not be a problem as it is considered compatible with DOT 3. Ed
- rstnick
18 Aug 2007 15:15
Yes you can use DOT 4 in the Kawi caliper or MC.
DOT 5 is NOT compatable with either DOT 3 or 4, which are compatable. 5.1 I can't recall.
Post edited by: rstnick, at: 2007/08/18 18:17
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
- Nelson
18 Aug 2007 23:54
cool, thanks!
