Stainless Bolts
  • jimmybon
  • jimmybon's Avatar Topic Author
Stainless Bolts
15 Aug 2007 15:13
#164115
I have a quiry about how to make stainless
bolts look black or darker in colour without painting or powder coating
It's been suggested that i dip them into boiling oil. The bolts are being
used for fitting bits and pieces to my bike eg guards, brackets, not
engine mounts or were high tencil is needed
any thoughts
cheers
James
74 Z1A900 original
74 Z1A900 stone replica
74Z1A900 barn find
77 Z650B1 Hybrid
81 z650 PIG camp bike
06 ZRX1200R cafe racer project
S1000xr
  • pstrbrc
  • pstrbrc's Avatar
  • '81 GPz 1100 project
Re: Stainless Bolts
15 Aug 2007 15:48
#164126
stainless can be anodized, but it's not very durable. But what's wrong with showing off your stainless fasteners?
\'81 GPz 1100 project
Elkhart, Kansas USA
\"Man does not control his own fate. The women in his life do that for him.\" Groucho Marx
  • ltdrider
  • ltdrider's Avatar
Re: Stainless Bolts
15 Aug 2007 16:02
#164128
If you heat s'stl, like with a blow torch, it will turn dark blue... kinda like your (well, my) exhaust pipes at the engine.
But heating it may affect the bolt's strength, so, now that I think about it, that's probably a real bad idea.
Never mind.
Edit:
Some s'stls are annealed by heat, but some are not. If your bolts are 18-8, a common 300 series material for bolts, then you can cook them and they won't loose strength. You could try flaming just the head of a bolt, since that's all that you see. That way, you won't take a chance on melting the threads or warping the bolt.
Post edited by: ltdrider, at: 2007/08/15 19:24
'76 KZ900 LTD (Blaze)
'96 Voyager XII (Dark Star)
Greensboro, NC
  • KZQ
  • KZQ's Avatar
  • Administrator
  • Administrator
Re: Stainless Bolts
15 Aug 2007 18:31
#164162
Most of the stainless I deal with in construction is needed for it's corrosion resistance. It's strength is actually lower than many carbon steels. Be very careful to use antiseize compound on any stainless bolts you use. Not sure about stainless into aluminum but stainless into carbon steel or stainless into stainless needs lubrication or it will gall tighter than you want to know about.
kzcsi
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
  • PLUMMEN
  • PLUMMEN's Avatar
Re: Stainless Bolts
15 Aug 2007 20:20
#164181
like he said,most stainless steel bolts are somewhere between a grade2 and a grade 5.
  • jimmybon
Re: Stainless Bolts
15 Aug 2007 23:46
#164205
I have heaps of chrome, polished aloy etc but these bolts are on several black parts and i just wanted to match rather then highlite the bolt
cheers
74 Z1A900 original
74Z1A900 barn find
77 Z650B1 Hybrid
S1000xr
  • The Gringo
  • The Gringo's Avatar
  • ¡Usted no necesita otra motocicleta!
Re: Stainless Bolts
16 Aug 2007 04:25
#164210
You might try using chemical bluing like they use for guns. I would think you could pick up a bottle for not a lot of money.
Andy
Akron, Ohio
80 Z-1 Classic-Sold
84 GPZ1100
79 KZ 1000 LTD
78 KZ 1000 A2
77 KZ 1000 LTD-Sold
KZ 550 times 2 80 440LTD-Sold
  • PLUMMEN
  • PLUMMEN's Avatar
Re: Stainless Bolts
16 Aug 2007 04:33
#164211
just heat em up with a propane torch till you get the color you want,it doesnt take that much heat.;)
